- 14 Jul 2005
- Birmingham
Ok having used my impact driver a couple times now I can see why they chew those bits up. They take a real pounding don't they.
aye, a decent impact driver won't be long shredding normal bits!Ok having used my impact driver a couple times now I can see why they chew those bits up. They take a real pounding don't they.
Chuck wobble. Try to Go a size down and hammer them in for a nice fitI've already snapped one screw i was driving into a piece of wood.
I think I need to work on my pilot holing. I always go too small for fear of making the hole too big. Except for masonry, for some reason I end up with holes too big despite using a nr 8 masonry bit with a brown plug which I thought was the right combo.
I've got that set, loved it at first, then found the quality OK but did go through a few doing a shed.. I then was left with Gaps in the box and I hate that..Another box of toys
Brown plug is 7mm bit iirc.I've already snapped one screw i was driving into a piece of wood.
*unless they can prove the cells are decent e.g. some no-brand Dyson batteries.No. One thing I don’t mess around with is dodgy batteries. They probably be fine but they might not be and I have seen enough scooters and hoverboards going up to realise it’s not worth it to save £20…
Nope no chance. Id buy branded items if its from a reputable seller on ebay is only exceptionDo people get third party batteries/chargers from ebay or uk stores?
Anyone got one of these? Looks interesting, but would like a user review
18V ONE+™ Cordless Patio Cleaner with Wire Brush (1 x 2.0Ah)
Patio cleaner in action, but aren't you removing more than you'd want to and making a mess?
I just use weedkiller.Thanks for the video, looks ideal to be honest, but I'll probably stick with my tried and trusted method
https://i.~ibb.co~/FhfGktg/PXL-20230529-153425208.jpg
https://i.~ibb.co~/zRxjnKW/PXL-20230529-153420368.jpg
I have it, it's great, depending on how much strimming you have to do I would go with the 12Ah battery though, or at least the 8HA.Anyone use battery garden tools?
I keep fighting with my petrol strimmer every year and thinking of buying the Milwaukee quick lock tool. (I have other tools from this brand so can use the battery’s)
Reason going for the quick lock I’ve just recently planted a lot of hedging so this can kill two birds with one stone.
