@Defy Belief
Could run a desktop in a small space, I run mine headless that gives me 4080 performance on my ROG.
- I've had good experiences tbh running things like streaming over my network before, but I dont think the money I spent on the XG would get me a much desktop better experience overall and i'd still pick native if I could@Defy Belief
Took the plunge and bought an XG Mobile 3080 to pair with my Ally yesterday, anyone else here doing this?
Can't see initially but will dig!See my pics above in this thread (or on a previous page if not using 80 posts (100?) per page.
In my case I got the 3080 XG Mobile with my Flow Z13.
Is it good? Worthwhile bump in performance?![]()
Awesome, thanks for the tips and it looks really cool, it arrives todayJust checked and it's post 514 in this thread.
Compared to the Ally directly it is a substantial performance uplift as expected. Performance is around a desktop 3070 albeit without the VRAM issues that have been dong the rounds (16GB vs 8GB).
I have a 7600/4070 Desktop so its more of a nice to have but is awesome from a docking perspective.
Only major downside is the XG mobile itself can be quite noisy if you don't set custom fan profiles. Would love if Asus just licenced the XG mobile interface so a "normal" e-GPU enclosure could be made to fit any normal desktop card. You would still be limited by the interface of 8x PCI-E 3.0 but its a sizable jump over TB4.
Just ensure you enable and disable the XG mobile before undocking the Ally. It should enabled automatically when the Ally is on and the drivers have loaded but you need to manually disconnected the XG mobile at a software level before you physically remove it. Not doing so can cause issues.
Had a quick test before I had to go out, mw2 ultra at 1080p was 50 fps, I expected better at this res, but unsure if there is any other things I need to do with drivers /configuration etc?Just checked and it's post 514 in this thread.
Is this the external 3080 GPU for the Ally? First time i've seen a pic of one thats not a review.
Yeah it is indeed and yeah needs a power source (charges ally at same time)Is this the external 3080 GPU for the Ally? First time i've seen a pic of one thats not a review.
Does it need external power I take it?
Will be trying that later for sure, this was just a quick plug in to testYou'll get better performance from the xg mobile on an external monitor connected to the XG mobile rather than using internal screen.
At 100fps on mw2 with dlss ultra, thing is pretty loud..but performance is great
@oweneades have you looked into replacing thermal paste or do you use a custom fan?
Edit turns out you need to open GeForce experience to install the latest driver, 134fps on mw2 now ultra dlss multiplayer
95c. Can also cook your breakfast omlette on it whilst playing. win win
Completely normal for turbo mode though with the watts etc95c. Can also cook your breakfast omlette on it whilst playing. win win
Has anyone had issues with external keyboards, this is now two games where often during gun fights when strafing / dashing etc, it then just keeps moving me in that direction as if in still holding the key down, it's really annoying, 99% sure the keyboard is fine. Playing returnal so not a forgiving game for it to be happening... Literally makes it unplayable, I've noticed just moving around it doesn't happen, if I strafe and fire with mouse at the same time that's when it does it
It's like it still is expecting joypad input rather than wasd?
