- 20 Nov 2013
- leicestershire
So how do i go about tuning this ram anyone got a guide? I see @LtMatt was advising people what to change from their zen timings.
Make sure your BIOS is up to date first.So how do i go about tuning this ram anyone got a guide? I see @LtMatt was advising people what to change from their zen timings.
thanks matt, ill run this overnight.
I am happy with the cpu and am glad I buy this over the 7800x3d.Going back to when Matt replied to you here....
Ryzen 7950X3D, 7900X3D, 7800X3D
Just bought the 7950x3d. What’s the best way to run this for gaming? I’ve seen people say that Process Lasso is the best way, but surely that’s not what AMD recommend. Would installing all the drivers as per AMD’s recommendations work just as well? I have watched some YouTube videos but it seems...forums.overclockers.co.uk
.....has anything changed much for you with your thoughts when you first bought a 7950x3D....? Not sure if this was your first AMD CPU but are you overall happy with it for performance and glad you bought that one over the 7800x3D..?
So a typical out of box experience, with game bar, is going to get the most performance from the 7950x3D without really working hard to achieve anything more..?
Thanks.
X3Ds are ahead of everything else at VR so would be the best choice.Has anyone tried pairing a 7800X3D with a 7900XT?
I'm going to be building a rig for VR soon, and will be supersampling with it, so was wondering about bottlenecks.
In the not too distant future the resolution of VR headsets will be going up to 4K (per eye), so will a 7900XT be enough if paired with a 7800X3D?
Or will I be better off going for a more balanced system and pairing a 7600X and 7900XT together?
I think so, but can be 100% sure.Yup, thanks, I already know that, but will I end up with a GPU bottleneck if I pair it with a 7900XT?
Mornin Gents, first i ran ram test at the expo settings for 6hrs with no faults, then i set all the changes @LtMatt suggested apart from tRFCsb as 50 was the lowest allowed. There was also a VDDIO setting that wasn't in zen timings it was increasing with the Dram voltage so i just set it to 1.35v, i ran VDD at 1.43 it ran for 30 mins ok so i went to bed, when i got up the computer had gone to sleep after an hr, i hadn't changed the power setting haha. Weird that it ran for 6 hrs the first time. So at least i know it ran matts settings for 1.5hrs with no errors.
zen was showing vsoc a 1.2951 with expo on.vsoc looks good, msi probably reporting default value and not applied one.
