brands yes, colours less so.Is there a difference between brands and colours of filament when it comes to bed adhesion?
Ah, that makes more sense then. We'll stop telling you to try different bed temps then!I dont have heated bed, just normal flexible magnet bed with masking tape on it.
Do i put hairspray on the masking tape or do i take the tape off and then apply it direct to the magnetic bed?Ah, that makes more sense then. We'll stop telling you to try different bed temps then!
Probably worth trying a glue stick/liquid/spray then. Hairspray is supposed to work quite well and fairly even, if you have it available to try.
 Clogged with Ziro PLA-CF (which had been printing really beautifully), cleared it and got a successful print. That gave me the spool adapters (cardboard spool no worky in changer
 ) so I could try the new roll of PETG-CF.  Jammed solid and it merrily kept printing nothing with the extruder skipping away.  Got it cleared so I thought but couldn't get a decent flow through it (by hand) even of straight PETG.  Managed some cold pulls but it just didn't seem to want to live.  Not sure if it's heat-creeped and welded to the tube above the heatbreak but it's not playing.  New nozzle/heatbreak/heatsink combo and it's printing but this stuff oozes something horrible (I see some retraction tuning in the near future) and didn't really stick to the G10 bed that well either.  Textured PEI bed and it's going but the first layer of support had a big blob in it where the head sat still for no massively good reason before starting.
