Caporegime
- 18 Oct 2002
Yeah I get it, made to hit a certain price-point with no other considerations. Mine was pretty good though, had no Ventus' since.They are awful, awful cards.
Never buy the worst, never buy the best.
The only cards I would try and avoid completely are MSIs Ventus cards. They are horrid. Thankfully the quality of even the cheapest 7900 cards seem to be of decent quality with no major corners cut.
Sapphire make fantastic cards tbh. They are kinda like the EVGA of AMD.
They seem to have high hotspot temp issues this gen, which points to a sloppy cooler mount/production issues. Only one I've heard doesn't really have these issues atm is Sapphire but that's just off various forums/reddit.but it’s unclear why folk think that.
I had heard complaints about MSI Ventus cards with the RTX3000 series.
Good to know, i would happily grab a Sapphire if it was an option. Powercolor seem to have, or had, a decent reputation however I’ve seen a few comments saying they dripped the ball this gen but it’s unclear why folk think that.
Afternoon, not sure whether I'm not searching correct or it's just me.
I've noticed my card is always up to 100% utilised in games, I'm using amd overlay tk check and it always says 100% when playing occasionally goes to 99 or 99. Temps are up to 71 so not unreasonable but it's always so high is it always utilising every inch of it?? Thoughts?
Yeah that is a very significant difference. From what I’ve been reading repasting helps a lot but personally I would be wary of doing this to a card under warranty, not to mention you shouldn’t bloody have to.I tested my aorus xtx last night after reading a post from another user here about his xtx nitro hotspot temp.
I Ran Time Spy and played a few demanding games, GPU temp max 58 to 65c but the hotspot temp 90c to 106c. I remember when I got the card back in Dec last year the delta was about 20~25c. The fan speed seems normal and no performance drop in games or benchmarks but the hotspot temp is worrying.
Repaste helps but have to wait for a few weeks for new paste to settle in order to see the final result. I did repaste 3090 FE before and the delta temp slowly increased every week after repasting.So it would seem there was an issue
Now I’m dithering and looking at a 4070ti but the 12gb really bothers me, as does the 192bit memory bus come to mention it. Decisions, decisions.
Glad I'm not the only one. What settings are you using.
Iv'e just run unigen heaven bench mark for 20 minets with amd adrenalin juntion temp 75c gpu temp 62c fan speed at 42% my gpu power limit is set to -10 % hope this helpsCan anyone who bought the 7900 XT Pulse tell me what max GPU hotspot temps they get while under load please?
I just put mine in a waterblock (The Alphacool one for the Nitro+ line fits fine with this by the way) and I am getting great GPU temps around 45-50C under load but hotspot is hitting 100C at stock speeds, 110C with +15% PL.
Stupidly I forgot to note down what I was getting with the stock cooler on so I'm not sure if this is normal or not - I suspect not but it's a real faff to undo the custom loop and re-seat/re-paste.
That’s not right that delta is hugeCan anyone who bought the 7900 XT Pulse tell me what max GPU hotspot temps they get while under load please?
Smells like a bad mount to me with possibly the block being at fault.I just put mine in a waterblock (The Alphacool one for the Nitro+ line fits fine with this by the way) and I am getting great GPU temps around 45-50C under load but hotspot is hitting 100C at stock speeds, 110C with +15% PL.
