Edit. Wrong PSU
So I'm presuming I'm all good. The ASRock card looks good, so I'll be buying that one as it appears to be better than the gigabyte. Thank you for the help.
if your planning to use both eps 8 pins to power the cpu then your gonna be 1 gpu cable short, if you just have 1 eps to the cpu power then it'll be ok
temped by the shift not long ago, took delivery of a dark power pro 12 1500w today, my overclocking antics were causing problems with my strix 1000w i did have
