How do I know the DLSS/FG mod is working? I modded before I even began so would it be an option in the settings or do I keep FSR on and that's really it?
rebar gives me a slight boost in fps, maybe about 5-10 but nothing mind blowing like dead space remake boost where it was 25+ fps. Vram dedicated usage has gone up by a gb too!
I've decided I have a minor but annoying quibble. Every time you land in the Mantis the ramp is at the back of the ship. Annoying.
, you can do it in ship builder.Thanks I eventually managed it. None of the guides mentioned pressing E!Target them (e), Hail (holdE) and then get close if they're allowing you to dock.
This, im hoping it comes in an update soon! Having to rely on memory is so darn tiring lol.
Thanks I eventually managed it. None of the guides mentioned pressing E.Target them (e), Hail (holdE) and then get close if they're allowing you to dock.
Apparently we're meant to memorise every town and NPC hub in the game.. We're just meant o know where to go.
Some of them are also like mazes, which doesn't help.![]()
.Bios enabled?
Nvidia only have it turned on by a whitelist so very few games have it on even though it is turned on via bios thus the need to go via profile inspector (unless you have this globally set which probably isn't a good idea as it can cause issues at times)
So desperate to play more of this. Darn work.
I’m working from home but there’s a bit of a lull at the moment and I’m sorely tempted to fire it upSo desperate to play more of this. Darn work.
Same... im on till 7, then gotta cook for the family so will probs be around 9 before i can get on.
I’m currently dossing from home but there’s a bit of a lull at the moment and I’m sorely tempted to fire it up![]()
