His posts get less annoying if you imagine "beep beep beep Russia calling, Russia calling" before every postYou must be on some mega money from Russia, for the ***** you put out.
I was thinking about rapid dragon again and then realised how ridiculously easy the concept would make nuclear first strikes, it's scary
If you didn't know, rapid dragon is a system that allows you to if you want, pre program a bunch of long range cruise missiles with targets, then pack them into these deploying crates and put them on a cargo plane, fly over the target and release the kraken. The concept allows a large cargo plane to carry 50 long range JASM missiles in the crates. So if someone wants to get in an early first strike, you take a commercial plane like a DHL branded cargo plane, stack it with these crates, add nuclear warheads to the missiles, then just fly your cargo plane on a pre approved flight over enemy territory because they think it's just a DHL plane coming to drop off cargo and instead you drop 50 nuclear armed missiles from the sky, let's say you sent 10 cargo planes and you've just dropped 500 nukes from the sky all now flying and within a couple minutes from their targets
It sounds like a ridiculous weapon concept that the West shouldn't have anything to do with.I was thinking about rapid dragon again and then realised how ridiculously easy the concept would make nuclear first strikes, it's scary
Errr…..and what happens to the crew of the cargo plane?
A strike of that magnitude would chaos utter chaos, they'd probably be able to just GTFO like every other aircraft.Errr…..and what happens to the crew of the cargo plane?
Like the MOAB? Which is basically just a big crate shoved out the back of a plane… Don’t mistake simplicity for uselessnessIt sounds like a ridiculous weapon concept that the West shouldn't have anything to do with.
Well nothing is impossible if you throw enough money at it but still, you’re a decade away from from converting a cargo plane from being able to do what is described. I think you’re underestimating the complexity of the task. And the huge number of ways it could fail.While not impossible to fully automate, it wouldn't even need a crew once airborne and on autopilot, though you'd probably have to relay comms as it progresses through different airspace.
yeah….no. It sounds like a mission with zero possiblity of survival - still, you can volunteer if you like.A strike of that magnitude would chaos utter chaos, they'd probably be able to just GTFO like every other aircraft.
I bow to your greater keyboard general status.....Well nothing is impossible if you throw enough money at it but still, you’re a decade away from from converting a cargo plane from being able to do what is described. I think you’re underestimating the complexity of the task. And the huge number of ways it could fail.
Theres probably a reason the west/NATO has spent untold billions on things like submarine nuclear deterrents, B1 bombers etc etc, and not converting banged up cargo planes to try and sneak nuclear weapons into enemy territory and that reason would be it being a ridiculous idea.
It's not though. It's the kind of weapon a terrorist state might froth at the mouth to own - but it goes completely against the idea of how the West should be conducting our defence. Just the threat of being able to sneak a devastating weapon system into a civilian aircraft - even if it's not used - makes all civilian aircraft a potential threat and a valid miliary target.I bow to your greater keyboard general status.....
I'm surprised they didn't want to tow it off and study it. Maybe it wasn't close enough to their lines to risk it.
And designed the Panther KF51 to combat it.It may also be a good thing, maybe with Erdogan publicly speaking up about this then some inside the kremlin may see it as a way to oust Putin as they would fear there is no other way outThat's pretty damning given Erdogan enjoyed playing both sides and was very much not critical of Russia and Putin in the past
Well there is the Politburo, technically they are the Russian leaders with Putin being top dog so to speak.There are no leaders in Russia. There's a single leader - Putin. How do you put bullets into someone who lives in a bunker and has 50K well paid personal security stuff?
Laserpigs take? Worth a watch for the lols for sure!There is a documentary on the T-14 Armata somewhere on Youtube, its ###### hilarious.
The irony is the Germans are taking Russias claims about the T-14 very seriously, perhaps because they apparently don't have a sense of humour?And designed the Panther KF51 to combat it.
So the Russians claiming they built a super tank caused the German to built an actual super tank.
Also a tale as old as time.
Russians are all about marketing. The world thought the MIG-25 was hot **** so USA developed the F15, an actual PROPER interceptor.
It was only after a defector gifted the USA one they then found it it was ****, just like all other Russian equipment.
That ended well for the Japs.If you were doing a pearl harbour attack and timing declaration to the same time it would likely be very effective.
