It's not,the game is CPU boundI'm a couple of hours in and enjoying it. The only problem I have is the performance of my 3090. 30-40fps with fsr2 enabled. Absolutely shocking!! How is this card out of date at 4k already?!
I'm not really seeing that much difference in performance,just looks a bit better with less shimmeringDownload the DLSS mod, runs a lot better with it enabled.
The game runs like a potato. No game should really be released so badly optimised. To get acceptable 60fps I need to lower the red to 60%.... Unacceptable on a 3090 at 4kI'm not really seeing that much difference in performance,just looks a bit better with less shimmering
Mines a 3080Ti which has similar performance,and even 1440p with DLSS struggles to stay at 60fpsThe game runs like a potato. No game should really be released so badly optimised. To get acceptable 60fps I need to lower the red to 60%.... Unacceptable on a 3090 at 4k
but then you get dumped in New Atlantis and a lot of the local missions seem to be fetch quest types.
Yea it's not really right that a last gen GPU at its price point struggles that much. It's almost like they do it on purpose to encourage you to buy the 4090Mines a 3080Ti which has similar performance,and even 1440p with DLSS struggles to stay at 60fps
Ya Hammy Joor, I litterally have one gold weapon I just got from doing a quest.....How...just how????I have about half a dozen gold weapons, the first one i found on the initial planet at the start of the game, i wandered over to some mine or base that had pirates in it. Explosive Maelstrom- shreds.
OK it seems I've turned into a bit of an idiot ... I installed a dlss mod and got no fps improvement but the game did look slightly better. Uninstalled and tried a different mod. Same results. Normally if I use dlss quality I get a noticeable increase in fps but no noticeable loss in image quality. So wtf am I doing wrong.
Currently Dynamic resolution ON
Render resolution scale 66%
Upscaling FSR2 (ie dlss due to mod)
Sharpening 80%
Bloomberg audience Q: Why did you not optimize Starfield for PC?
Todd Howard: we did... you might need to upgrade your PC
Must be a random drop, I got a rare gun I think.I killed the pirate captain from the first quest and got a gold gun from him. Is that a random drop? I successfully negotiated a peaceful resolution first, for the xp!
