YouTube Premium
I've just been kicked off my Indian plan after about 3 years :eek:
My bank cards are both being declined (Barclays and Halifax) I'm just not sure yet what to do and I don't yet have a Revolut or Starling or anything like that. Which one is best do you think?
Doesn’t matter, just go to Ukraine.
If you watch it on the PC and use then this addon called AdGuard Extra seems to block Twitch ads for me, there's no UI its just an addon for any other ad blockers.
Supports Firefox as well but it seems that it has to be installed manually on that browser.
ooo i'll try it out thanks.
Asked me to update mine and I used my 1st Direct CC and it went through no issues.
Not sure if it's been mentioned but for smart tvs just use SmartTube even skips the in video sponsors and intros most times.
Caveat being that not all Smart TVs support sideloading apps like SmartTube.
https://www.reddit.com/r/AndroidTV/comments/sbkxo7/looking_for_a_tv_that_lets_me_use_smarttubenext/hu0fb2e said:
LG uses webOS, it's not compatible with Android apps. The same with Samsung and their Tizen OS. Fire TV Stick uses Fire OS, Amazon's fork of Android and hence is compatible with Android apps. Nvidia Shield runs Android TV and is fully compatible. Ideally you want to make sure the product description states it runs Android TV or Google TV.
I have an LG TV and pay for YouTube Premium.
Had the same, been failing since Friday until it paused yesterday. Used my Revolut virtual card, problem solved. Still in India :)
Noticed on three occasions today, ads (inital ad when you click on the video) kind of getting through ublock origin on firefox. There is sound but no video. Refreshing fixes this. Never had this happen on PC before. The end might be nigh. I may need to move to indian or Ukraine like some of you.
Just tested a Revolut virtual card and the regular one but it's still a no go for me :( Mine is for a family plan and a few people around the web have reported individual accounts working but not family plans so maybe that could be the problem with mine, I'm not really sure :D
I haven't had a chance to test out some other countries just yet but I'll give it a go later and report back!
Am.i doing something wrong?
Tried Argentina and Ukraine on NordVPN and it comes back either with UK pricing or says "can't verify country"
Any tips for a nublet?
If Nord has the double encryption. Cant remember what it was called. Enable that option and try again.
Most likely the IP the VPN is using is already blocked. Nord is a trash VPN, try a different one.
Interesting. My 3 years of Nord are about to run out in November so this may come in handy if it's as fast? Oh I just clicked it's the same Proton that do ProtonMail. Nice.
Yep, no problems with it. Find it better than Nord due to more servers, like in India.
Following on from my previous posts where i keep crying about not being able to setup the Ukraine account. Any chance someone would be willing to give it a go on my behalf just to rule it out being me?
I can set up a virtual card for it, so happy sharing the info
I'm fairly certain I had the same thing when I tried too. The instructions said to just try again at a later time. I checked back after a couple of hours, but it ended up being the following day before it worked, but it did eventually.
