I'm on K&MSeems to run OK so far but need to sort my controller out, it's going crazy for some reason.
Camera was way too fast as well at the 1.0 speed, I could circle around my character far too easily.
You have the right idea with the lamp, the little healing orb is in the umbral, use your lamp to see it and then absorb it in the same way that you absorb blisters (left mouse button in the case of K&M), you dont need to fully rift into the umbralI'm liking it so far, just soloing as the condemned which is definitely a harder start, but feel like making good progress so far. Dual-wielding broken buckets was funny!
Couple of things I haven't worked out, when you're in the land of the living and you get one of those enemies with the little ball thing that you need to take out before you can kill it, how do you actually do it?
On my game if I target it, and then pull on it using the lamp, it doesn't seem to die, and then the enemy just rejoins it and goes invincible again, am I meant to attack it? not really sure maybe I didn't read it carefully enough in the tutorial bit.
I found the only way to kill it was to rift into the umbral realm and then take it out.
Also not sure what the bar is underneath the health/stamina, is it mana?
Be sure to hold the button down for a bit, it takes a while to fully destroy itYeah it's weird just doesn't seem to work, will give it another go though when I jump back on later.
I'm grinding out some levels before I tackle the boss again, I'm trying not to use the iron guy you can bring in for the fight as well.
I think they're just for loreDo the memory fragments do anything except for show you stuff btw? I figure they don't.
