Shame it’s about 300,000 troops, 5000 tanks and 7000 artillery guns late.
48 hours later they're looking for a charger.. So this is more likely going to be attached to a vehicle.
Pity a grid ref is all that's needed for artillery.
Probably issues getting that many to the front from NK, and the barrels of the guns are probably also in short supply.
I imagine part of the reason they're firing fewer shells is because the artillery Ukraine has now is a lot more accurate. Meaning they can't fire many shells before having to move or getting hit.
IIRC at the start of this, and probably still now Russia was basically using 1930's logistics methods, pretty much everything loaded manually onto trains and then off them onto trucks, again manually.Russian logistics can be poor as well for example 2 cases recently where newly mobilised forces, one never had their ammo turn up and the other found it had been dumped randomly in a village 10km or miles from where it was supposed to be. Russia is probably highly dependent on railways for lugging 120+mm shells in bulk and Ukraine has been trying to hit their logistic hubs.
Of course, the armchair generals keep telling us Russia is only using 5% of their Strength so far, they must think we're bloody stupidSurely they are holding the best of their ammo for later on. Previously they have only been using their limited reserve ammo.
Just like their soldiers and tanks etc ……
They finally rolled out their top kit?Looks like the Russians made another two pronged attack to the east. You’ll never guess what happened…
Their artillery usage has been constantly dropping off for much longer than just recently. No sane observer has says they will run out completely. But if usage drops too far it has a dramatic effect on Russians operations regardless.
So sure some people here have been exaggerating too optimistically, but you have been doing the exact opposite, exaggerating the other way by constantly making out the Russians are better equipped than they clearly are.
There's a realistic middle ground between the two extremes actually based on the evidence.
