- 19 Nov 2021
- Portsmouth
Thanks for mentioning this, I had no idea it existed - ordered one for exactly that reason. Hopefully it arrives today or tomorrow.I wonder if the new Zwift Cog will fit a Wahoo Kickr Core.
Would be brilliant for me using my mountain bike and constantly running out of gears.
Be aware though that it only works with the zwift app. (ie, the click buttons tell the app you've shifted, which then tells your trainer to change the resistance)
