Of course it's track specific. That's why other teams had to raise their ride height for the circuit to ensure they'd meet the regulation.
Compared to Middle East i guessThought it was interesting that Hamilton praised the US for being progressive... must have been those tollerant progressive Americans that booed Max.![]()
I'd certainly agree that, based on finding one car failing they should have checked all of them.We know RB and McLaren potentially did. Looks like Merc and Fer didn't. So what about the other 6 teams? What about Hamilton and Leclerc's teammates?
I'm sorry but if you find 50% of your small sample size suddenly reveals something that hasn't been penalised with disqualifications at any point in recent memory, that would highlight to anyone that something about this specific track has made something go wrong.
This all seems like a massive failing of how they enforce a technical regulation like this.
Looks like a win win for Norris, as well as bagging the P2 with Hamilton's DSQ, he's also overtaken Leclerc in the standings due to his DSQ.
If anyone had their ear in the stewards ears, I'd have thought Zak had a lot more to gain from it.
I think we all know it is. They would easily have enough money to have a team to inspect every single car individually, immediately after every race.Genuinely blown away that the top level of Motorsport doesn't have the capability to do even basic post race scrutineering on every car.
Is this another example of F1 earning the FIA huge sums but spending it elsewhere ?
Even if it's not track specific, if you're looking for something that is worthy of a DQ then it should be done to the entire field surely. It's nuts that there could be 6-7 runners out there that would have failed the same test yet have gotten away with it, no, correction - been promoted because of the spot checks.I'm sorry but if you find 50% of your small sample size suddenly reveals something that hasn't been penalised with disqualifications at any point in recent memory, that would highlight to anyone that something about this specific track has made something go wrong.
And why can't the cars just run as low as they physically can depending on the track? What's the danger anyway? They go too fast? I dont understand this having to run as low as you can to get the performance but "not too low mister otherwise you're a naughty boy"![]()
Fair enough. Isn't that likely to happen quite a lot with these ground effect cars anyway? I mean, that's what porpoising kinda is anyway - when they bottom out. Yeah, I still don't like this ground effect..It was introduced after the deaths of Senna and Ratzenberger. As I understand it, it's considered a big risk because if you rely on it for grip then if you lose it because you hit a kerb/bump/other car/whatever then you suffer a massive, sudden loss of downforce making the car completely uncontrollable and likely to collide with the wall at very high speeds.
Except when they’re notRules are rules!
Sure it has happened before in the late 90s / early 2000s. This article says Schumacher was disqualified shortly after the rule was introduced in 1994.Anyone know of the last time anyone was penalised for this worn plank thing?
People losing their mind over a "sampling process" finds some samples out of spec, then state that they expect for all cars to be tested each time, well that's not a sample then is it.
Lol make up your mind.We are not saying that. People are saying samples are fine, but if either:
a) A significant proportion of a sample size fails a test
or
b) Anyone fails any test
Then that test should also then be repeated for all cars. Otherwise what's the point? Sample sizes are to speed up and lower costs of checks yes, but it is to allow you to home in on problem areas to look more deeply at.
