This. I can’t recommend them enough.Is it a dot and dabbed plasterboard wall? Just use corefix fixings.
As a yorkshire man that sentance scares me the most, that seems very excessive for paper.Cursing. Crying. Swearing like a pirate.
TV has been off and on the wall a few times, and each time I'm saying "we need to stop pulling the TV out to max extension, the fixings aren't good enough", but because this is weekend 5 of painting and decorating and fitting skirting and beading.. I haven't sorted them. And we need it pulled out to see it while the sitting room is in chaos. Cos the old sofa is in the wrong place at the mo.
Well the bloody thing committed suicide this morning while I was in the garage and due to a new sofa turning up this coming Tuesday I can't repair the wall until other jobs are done.
So.. plasterboard finding tomorrow.. chopping out the damage.. sorting the blockwork wall behind for some proper fat rigifix or equivalent.. refit plasterboard.. fill.. sand.. fill.. sand.. paint.. paint again.. that's my free time next week gone!
Oh and in the crash it marked the brand new wallpaper which is 200 notes a roll!!
Hence mostly swearing...
I'll dig out the name of the fixings I used but they have a metal sleeve that goes in to the plug to add extra support. I also put some instant plaster (tube) into the wall hole before putting the plug in. I suspect the house will fall down before those bar stewards come out.Sure is. I'll Google them. I did use rigifix but even those started to shift after a few years. Which is why the got replaced before decorating started, apparently replaced extremely badly.
Knee pads?Spent all of yesterday screwing down all the 1950s square edge floorboards in our soon to be new bedroom. It took a long time because there’s a fair few cables and pipes. All done and no leaks or zaps… feeling it today after being on my knees for 6+ hours.
Timco C2 clamp fix screws would highly recommend for this if anyone is planning it. I pilot holed everything but those screws pull the boards super tight to the joists. Walking over the floor now it’s silent. No creaking at all. Glad I chose to do this.
Sounds like core fix.I'll dig out the name of the fixings I used but they have a metal sleeve that goes in to the plug to add extra support. I also put some instant plaster (tube) into the wall hole before putting the plug in. I suspect the house will fall down before those bar stewards come out.
The paper is from the Designers Guild. It is beautiful but also crazy price.As a yorkshire man that sentance scares me the most, that seems very excessive for paper.
How deep did your old fixings go into the wall, people often forget with those cantilever mounts how much force its putting on the wall at max extension.
Must be a weekend for it - Spent Saturday fixing several loose/squeaky floorboards in one of the Kids rooms, and then laid some new Underlay (Carpenters' Richstep 9mm).Spent all of yesterday screwing down all the 1950s square edge floorboards in our soon to be new bedroom. It took a long time because there’s a fair few cables and pipes. All done and no leaks or zaps… feeling it today after being on my knees for 6+ hours.
I've got knee pads, but find them too bulky. I've settled on using a gardening kneeling pad for these sort of jobs.Knee pads?
Yeah correct. Only if it's over a certain size. Didn't go any larger on my log burner as I didn't want a ventilation hole putting in the wall.?? only if it's over 5kw ? .. had my wall done cause mines a 8kw .. and we don't do doors downstairs .. still had to do it ..
I had them and was wearing them. Feeling it in my lower back and hamstrings, knees are okKnee pads?
I can make a go fund me for you to get a new monitor?@dlockers can you post larger pictures in future please?
I haven't sold my soul to the devil so I don't use Chrome.I can make a go fund me for you to get a new monitor?
Seriously tho chrome my end resizes it perfectly? Or is it the forum software
Pictures are massive in Edge also so I guess it's forum software, or you could just make them smaller.![]()
Is it a forum software thing @kindai ? They appear perfectly sized for me, altho sometimes I do get a glitch where they show at actual resolution.And in Firefox too. Nightmarishly large
[img width="1200px"]pichere[/img]
