- 28 Sep 2014
- Scotland
One of the worst and IMO truest comments there on Western support: "They have left him without the means to win the war, only the means to survive it."
I find it grotesque how little comprehension there seems to be of the bigger picture here.
I don't think there is a "a new strategy, a new message" - Ukraine is merely surviving right now and even at this point I don't think the consequences of them losing is really being comprehended in the West.
Trying to play the game of a stalemate sadly, hoping Russia will eventually give up dosnt look likely though.
Written by a Russian.....
The big problem now is, they're not indefinitely sustainable, but they are sustainable for the foreseeable future, I.E they can sustain the current loss rate of tanks into 2025 at least. I didn't think it was possible before but now with the wests attention potentially turning towards Israel/Hamas conflict, I worry there is actually a real possibility that western interest in helping Ukraine against Putin may go the way of western interest in helping the Syrian rebels against Assad![]()
So why would they then give up?
Problem is Ukrainian man power isn't infinite, trying to turn the conflict into a large, almost frozen, stalemate isn't going to work and Ukrainian ability to fight is going to be degraded before Russia under those circumstances.
I think Ukraine needed to follow some NATO type doctrine in acceptance of the support. Rather than the one they would have been far more familiar with which was basically the soviet one.
They did, and it didn't work.
They seem to have found a hybrid that sits between and is working fairly well.
Also I think they expected too much. They should have pushed far harder near Bahkmut. Russia had basically prepared little defence there as they had been on the offence.
In the South they had been digging in for almost a year. Even now as they fall back they start digging again. Slow crawl forwards keeps giving them time.
Bakmut has no stragetic value and doesn't further them to the final goal, which is Crimea. It's also hard to follow NATO doctrine when you don't have a key component: air superiority.
I think thats partly what they did/are doing. Hit Backmut, Russia defends it, so hit by Robotyne. Forces pulled here, hop over the Dniper river, pull resources again, move somewhere else, rinse and repeat. Russia has to go the long way round to get from one hot spot to another, Ukraine can go 'straight line' through their own territory.If it started collapsing Russia would have needed to either concede lots of the gained land (which would also make their supply situation more difficult), or start pulling more and more troops from the South to hold.
Agree in regards air superiority, which was my issue and point. They were clearly using NATO equip to NATO doctrine, but with limited success.
I suspect the senior military are hard to move from their historic position.
I wonder if there is a window here for Ukraine to push the air war - I've written and discarded a longer post a few times because a lot of it is highly theoretical and/or not available right now but I reckon if Ukraine could rapidly put a Gripen w/ Meteor and Spears along with GlobalEye AEW&C into an aggressive air campaign there is a window right now they could do a lot of damage - Russia would ultimately respond to that so they'd have to play it smart and unlikely to be able to gain and keep the upper hand in the air but who knows - Russia's true strength in the air hasn't been tested though ultimately it would probably need a hard-hitting campaign pushed into Russia to cripple their capabilities.
Russia seems to be at their weakest currently in terms of being able to respond to that, but they aren't lacking the ability to respond it might just take some time with the apparent maintenance issues and unwillingness to fully spin up their S-400 systems currently.
Have they been given those planes? (Genuine question.)
The first US-made F-16 combat aircraft that the Netherlands is donating to Ukraine will arrive in Romania’s training centre within two weeks, outgoing Dutch prime minister Mark Rutte said on Monday.
Nope, there has been a lot of talk about F-16s and to a lesser extent Gripens but so far little real progress.
EDIT: The latest on that:
I wonder what the pilot conversion time would be like for the Gripens? You wouldn't think they'd be a million miles away from the F-16s in terms of the way they operate (or even the MiG-29s).
Couldn't really say - the Gripen is very digital, compared to the stuff like MiG-29s which are very analogue - so probably quite rapid conversion for those pilots used to modern hardware but maybe a struggle for the more old school pilots.
