Seems like as usual Samsung really missed a trick there, they *always* seem to fall short on something!i would really get one if you could properly use PIP modes and it had more capability, but in the end these super ultra wides cant be used to act as if they're 2 monitors. just having a super long screen is a bit pointless.
also need DP 2.0 to become more mainstream
HDMI 2.1 can also handle it from what i've seen on reviewsYou won’t be able to run the screen at its full potential without a DP 2.1 capable graphics card, and only AMD have a few of those at the moment. The NVIDIA 4090 doesn’t have it
G9 OLED was fantastic but ultimately a little big for my needs, so I just got a 34in DWF and pulled it a little closer and bingo! Perfect
Have they managed to get 240Hz at native res? I was limited to 120Hz on a 6950XT via HDMI 2.1. Just got a 7900XTX, and I must admit this monitor is a joy to use at 240Hz.HDMI 2.1 can also handle it from what i've seen on reviews
I've requested an 'in home repair' but still waiting to see if they accept this. None of the home repairs that have happened in the States appear successful. Sounds like a fault between the power supply and logic board.Guess you can't ask for a refund? I would wait a good few months before they are back on sale so they can sort out the problems.....if they do!
				 youtu.be
					youtu.be
				Anyone ?Just got the 57 g9. Pretty good monitor - very bright, does creak a little when first switch on!!! quick question for fellow owners-, When you put a grey background on screen, do you see a darker rectangle perfectly in the middle of the screen. Will be highlighted if play below video and is most noticeable at around 1 minute mark. Likely something to do with the mini led matrix>? Disappears when screen becomes lighter and also less noticable with cool color as oppose to the warm setting. Just checking if this is a 'feature' before i think about returning.
Gray To White, Grey Uniformity, Clouding, Banding, Test - For OLED QLED IPS (4K UHD SDR No Sound)
Full-screen stepped ramp from 0% White to 100% White. Due to video compression and/or YouTube tone-mapping artifacts, you may need to compare this with other...youtu.be
Mine died. Waiting on a 'refurbished' one with some panel damage I got for half price to arrive, and then I'll let you know. I'm too impatient to wait for new ones to come back in stockAnyone ?
 No doubt this replacement will also die in a few weeks knowing my luck!
 No doubt this replacement will also die in a few weeks knowing my luck!Anyone ?
Thanks for checkingI don't see any darker rectangle in the centre of the screen. I do however see horizontal banding lines on the bottom 40% in some parts of that video.
