What's with having two Pi-Holes? Are they on different subnets?Updated after a couple of changes.
Pi 4, 4Gb. Pi-Hole.
Pi 4, 2Gb. 2nd Pi-Hole. Kept in sync with primary Pi-Hole using mavity sync. Runs an rsync job to download backups of my UniFi controller and push them to OneDrive.
Pi 4, 4Gb. Flight tracker reporting to Flight Aware & Flight Radar 24. Also running a RIPE Atlas Probe.
Pi 4, 2Gb. PiVPN (WireGuard & OpenVPN) & Cloudflare Tunnels endpoint. Soon to be a 4Gb Pi.
Pi Zero 2 W. Running Mosquitto, an MQTT broker that feeds into Home Assistant.
I've moved Home Assistant to a Home Assistant Yellow which uses a 4Gb Compute Module 4.
I don't know about @the-evaluator but I run two for redundancy using Pi Zero 2s with ethernet adapters. They both run DHCP and my scope is split between them. Each one gives out itself as primary DNS and the other one as secondary.What's with having two Pi-Holes? Are they on different subnets?
this is pretty much why I have it setup with two. just means you don't have to mess around as much if one dies.No, same subnet. I have two for redundancy, useful for when (not if) a micro SD card dies. Useful for when I want to update one of the Pi's so can take it offline without any impact. It was useful last week when one of them went down due to a failed PoE HAT.
going full klipper?Just dipped a toe into this and got a pi4b 4gb, running 2 octoprint instances with webcams on two 3d printers.
Quite enjoyed getting them set up….need another one now lol
May do in the future, need more reading.....meaning I dont know much about Klipper.going full klipper?
yes. but then my 3d printer is more of a project than a tool. most of what I print are upgrades for the printer!May do in the future, need more reading.....meaning I dont know much about Klipper.
Would you say it's worth it?
Thanks, given the price difference I decided to just get a Pi Zero 2 W.Pihole will work perfectly adequately on an original pi zero
Yeah but I probably overcomplicate things.@Feek I believe you have this?
