OP stuff like covert sneakers
The Covert Sneakers are the best thing in this game compared to MW2. I can now run around and be aggressive without being heard from 20 metres away.
Wife has it, i don’t find it comfy at all!I like the official Pulse headset
Decided I need a new headset. Not being able to hear footsteps is killing me. What are people using that footsteps are easy to hear from behind? Cheers
Right so basically you want to have zero negative consequences for being completely silent all of the time but still be able to run around at full speed? They can’t be countered and there are pretty much zero negative consequences for running them. In terms of balancing that’s the very definition of OP.
I expect a nerf will be incoming very quickly. Either to further limit loadout, reduce movement speed etc or for them to be quiet but not silent. Perhaps even a counter of some type with something like bone conduction.
Yes I do want to be able to run around with silent footsteps. As I've had to put up with elephant footsteps for a year with MW2, it's nice to not have super loud footsteps.
I would take quieter footsteps. So have them like Ninja rather than Dead Silence.
As it stands base footstep audio is far too loud. You can pinpoint somebody's exact location through multiple walls. That's the main issue.
We always had silent footsteps as a perk - going back to COD4.I agree, base footsteps are too loud but the answer isn’t to counter that with totally OP perks.
Seems like an odd design choice given how much easier reducing base footstep volume would be, but that’s just me.![]()
The issue is bone conduction is a bit useless as they're still completely silent, they should cancel each other out or at least make it something like 50-70% volume. I remember in the original MW3 (2011) sitrep pro cancelled out dead silence.We always had silent footsteps as a perk - going back to COD4.
It was only MW2 2023 and MW2019 that IW decided to change Dead Silence / Ninja to a field upgrade.
The idea of going back to waiting for my field upgrade to be available so I can run silently around the map without some sentinel sat in a corner waiting to get his 4th kill in a 15 minute game is just nauseating to me. So many MW2 2023 TDM games that just ended by the timer rather than the kill limit because of it - it just encourages everyone to play slowly when you can hear every footstep across the map and the counter is just waiting.
Having a perk that gives you silent footsteps is needed and it's great that we have the choice. I use them on around 50% of my classes but I actually find the Stalker sneakers are incredible for the strafing speed advantage you get with them. It catches a lot of people out when you suddenly strafe much quicker than their expecting.
MCW is a great AR! What are you using with it? There are a few really strong ARs (Holger is slow but hits hard, DG58 will get nerfed at some point to reduce the 1 burst) - but outside of those two, the MCW is my go-to assault rifle.I hate all these attachments on the guns , i cannot see any defference
Being using the MCW its utter terrible , you shoot someone and the damage is ***** even at close range
Ive been playing around with the MCW for hrs but i cannot get the right results , when i am locked on to the enemy player and shot the aim always goes above the head of the player , maybe i am doing something wrong ?MCW is a great AR! What are you using with it? There are a few really strong ARs (Holger is slow but hits hard, DG58 will get nerfed at some point to reduce the 1 burst) - but outside of those two, the MCW is my go-to assault rifle.
I only ever use the Holger in SnD - and the DG58 if I'm playing against someone who is spawn camping / also using it.
It's a pretty static AR in terms of recoil, I like using iron sights on my one but you can swap the rear grip for an optic if preferred.Ive been playing around with the MCW for hrs but i cannot get the right results , when i am locked on to the enemy player and shot the aim always goes above the head of the player , maybe i am doing something wrong ?
