So I tested my U6-Enterprise on the ceiling and definitely getting better speeds.
It’s now powered by 2.5Gbe Zyxel Poe+ injector.
I tested speeds around my flat and the worst I’m getting is ~270mbps on 5Ghz band by the main door (where I usually don’t spend much time obviously) so will be only using this single ap instead of 2 like I did before (was using 2 AC Lite to cover my flat).
Here are speed tests from my iPhone 13 Pro Max while sitting on the sofa and from my Quest 3 in my usual play area.
