AMD brings back consumer HEDT, launches TRX50 platform, Threadripper 7xxx
28 May 2007
I see EVGA still do a 2kW PSU. Hurry while stocks last! Does anyone else do a non-mining PC PSU with that capacity?
Most IEC connectors are rated for 10amps so 2400 watts would be about the maximum possible without using 2 leads. Over 2kW is sailing pretty close to the wind.
20 Oct 2002
Derby
I am sure that with enough cooling(Probably LN2) and balls you could maybe get it to pull close to 12-1500w. From my testing with PBO enabled and using a Full cover AIO With the fans on a standard profile i was seeing almost 800w on the 7980X and about 765w on the 7995WX. What i did find amusing was that the PBO performance of the 7980X was almost on par with the 7995WX at stock. The both CPUS were getting about 17-20% performance increase with PBO Enabled. The thermal output went significantly higher, i was seeing 71DegreesC max on the 7980X and 65DegreesC max with the 7995WX at stock. They both reached 95DegreesC with PBO Enabled.
