Caporegime
- 9 Nov 2009
- Planet Earth
It was very safe on my wallet at £95.
I get the feeling it won't be so safe next gen![]()
It depends on what the RTX5070 has in terms of hardware. If its 12GB you will be probably fine for a while. If its 12GB and has that neural compression technology,Nvidia is working on and its locked to the RTX5000 series,or ships with more VRAM,then you might have to upgrade. Then the other issue is what type of CPU and RAM requirements we might need in some of these future games,especially since DDR5 might also be needed.
Personally,looking at **** UE5 seems to do so far,I think I am just going to wait and see what it really needs and move on from there.
