- 18 Oct 2002
Slightly smaller screen on the 7a but you still get the 90Hz refresh rate, so handset is also a bit more compact. Pixel 7 will feel a bit more premium in the hand as the 7a rear is plastic and not glass. Bigger camera sensor on the 7 might also give you slightly better low light shots. Charging is also faster on 7.
If they are the same price, I'd go for the Pixel 7 over the 7a.
If the Pixel 7 was £50-100 more expensive than the 7a, I'd just get the 7a, as the minor improvements of the 7 wouldn't justify the additional cost.
