Morning seems my son's switch no longer charges without us having to manually hold the charging wire or dock under pressure. I presume the internal connector is borked. Any easy way to fix or is it dead?
That would be awesome if u could do that. Clearly I'll sort you out.
I think I sent a DM...not sent one since the forum upgrade.
@Vince - have you come across any issues with Switch Docks that won't produce any display on a TV? Mine charges the switch fine, but doesn't seem to want to display anything in docked mode. I've tried replacing the HDMI lead, different HDMI port on TV etc, as well as fully powering down the charge etc.
Just wondering if it's something you've come across and whether it's likely to be the dock at fault or the actual switch?
Thanks for the quick reply - I'll take a look laterCould be either most likely the switch - The switch charge port has 10 lines that go to a chip called PI3 and that controls docking. 9 times out of 10 its the port or a blown filter (normally caused by the port) on the lines that go out to pi3. Have a look inside the port do you see any bent pins? Normally crossed data lines in the port at fault.
Thanks for the quick reply - I'll take a look later![]()
Appreciate that - thank youIf you need a fix let me know and I can fix it up for you also - just popping a new port or some filters on isn't exactly hard work for me and I have a ton of donors and new ports so if you end up down that road and want me to fix it for you just shout![]()
@Vince any interest in that Dell precision 5520 laptop I mentioned ages ago, new boards are still hundreds and hundreds and as its still a capable machine, wouldnt mind resurrecting it for one of my daughters. It has an Nvidia m1200 chip in it so would still play their games fine.
Ive waited patiently waiting to see when you ran out of work but seem to be flat out all the time!![]()
you got my deets? I did that ryzen 9 / 2080 one with power issues so giving this a bash cant be any worse lol. I wonder how that machine is getting on it came back after the initial repair with more issues which we fixed and rolled it back again! Hopefully its still going strong! @embalse - How is she doing fella?I can pm you, you did say way back you were buys and to leave it a while, its not my main laptop so wasnt in any hurry for it. cheers.Yea man swing it to meyou got my deets? I did that ryzen 9 / 2080 one with power issues so giving this a bash cant be any worse lol. I wonder how that machine is getting on it came back after the initial repair with more issues which we fixed and rolled it back again! Hopefully its still going strong! @embalse - How is she doing fella?
You do sometimes have to nudge me on things as I cant remember everything - Most of the time I cant remember yesterday!
PM'ed, im in no rush, its been sat for well over a yearWorks for me - If I have a massive backlog im always a bit cautios about taking things on as I cant guarantee how long a turnaround will take me. Some people I end up with their stuff for months so I try and be careful and realistic. Right now im pretty empty got a power supply and a few other items but its not crazy!
