- 25 Dec 2009
- London, UK
I do need 64GB, however I would like the timings to be min CL16 3600mhz or I'll just get another kit.It should work, but overclocking is going to be harder. The sweetspot is 32GB because its dual rank and 2 dimms for easier overclocking. Are u looking for the best overclock or do u need 64GB ram?
Its b-die so you can getting lower timings with volts. Ofcourse you should follow a guide:I do need 64GB, however I would like the timings to be min CL16 3600mhz or I'll just get another kit.
A quick google on the Gigabyte B550i Aorus Pro and seems other people have also reported same issues with dram voltage. Are you running the latest bios? maybe this has been addressed now.How? Damn. I've got the exact same setup as you except my mobo is a Gigabyte B550i Aorus Pro. I can't get this to even boot at 3800, always have to clear CMOS but it boots at 3866 which is odd, you think it's voltage + Rtt + drivestrength?
Heck I was running it at 3600C14, 140 tRFC (ns), tight timings, 1.45v which is actually 1.5V reported in BIOS and HWINFO as this motherboard overvolts everything (does yours do that on vdimm as well?) and it passed every TM5 for 24 hours, super stable until a few days ago, just browsing got a CRITICAL_PROCESS_DIED BSOD and it killed my SSD, literally. Bios doesn't find it on any m2 slot.
Are you actively cooling the ram as well?
I had to clear cmos only when trying to boot 3800, as it never booted. I am on latest bios yes. My case is also an AP201 with great airflow, I don't know why even 3600C14 isn't exactly stable as it should be really frustrating. Even after all the tests, stress tests etcA quick google on the Gigabyte B550i Aorus Pro and seems other people have also reported same issues with dram voltage. Are you running the latest bios? maybe this has been addressed now.
In regard to rtt 6/3/3 worked best for me, drive strength depends, I started with 24ohms then dropped it to 20ohms once I was stabilized timings. With voltage you can initially set between 1.5 - 1.55v and will be fine with b-die. Once you have your timings stable you can start reducing voltage. For me 1.5v was not enough for tCL 14, I had to bump it up to 1.51v to get it stable.
Your m.2 SSD dying sucks, although with older bioses in the past when I was tinkering with my x570 master I ran into a similar issue where the mobo would not see my m.2 boot drive, I had to switch to the 2nd bios profile to boot back into windows, so it could be the mobo rather than a dead m.2 drive. Also it is odd you always have to clear CMOS, as far as I am aware that's not normal, at least I never had to do that when tuning my kit. One thing is clear to me, my next build I will be staying far far away from Gigabyte mobo's and depending on how things go AMD entirely.
I do not actively cool my ram, there's no need at 1.51v, active cooling would only be required (as far as I am aware once going into the 1.6v territory which I would just not risk personally).
I was actually able to boot into windows at 4000mhz but eventlog filled with WHEA's, I think I had to clear cmos once when testing tighter timings with 4000mhz.I had to clear cmos only when trying to boot 3800, as it never booted. I am on latest bios yes. My case is also an AP201 with great airflow, I don't know why even 3600C14 isn't exactly stable as it should be really frustrating. Even after all the tests, stress tests etc
Welcome!hello im new
built my first pc and enjoying learning overclocking, got the 8pack bdie 2x16gb kit paired with a 13700kf thought i would share they are running great and taking voltages well (would have loved a temp sensor) i have them in gear 1 at 4100mhz 15-15-15-15-35-282 all timings done at 1.55vdimm (fan cooled by a 140mm case fan locked at 1500rpm) i think they can go further like 4266c15 1.58-1.6v but im not very comfortable hitting them with 1.6vdimm even though people say bdie can take it if well cooled just dont want to play the guessing game with the dimm temps due to not knowing what they are
I have 4x8GB running C14 3600MHz with a 5800X3D on an X570 Aorus Master.I have the 8 Pack 2 x 8Gb of the CL14 3600 ram.
If I buy another set of the 8 Pack 2 x 8Gb CL14 3600 ram will this work just fine with my 5800x3d?
16Gb -> 32Gb
I assume the DOCP profile will work just fine with 4 sticks?
Follow this: https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.mdhi guys, wondering if i could get some help. I bought some 8pack ram in 2021 that was advertised as B-die ram. Im really struggling to get any sort of overclock out of them at all. If I up the speed to 3800mhz my pc wont post. If i tighten the timings at all the PC wont post and I have to flash the CMOS in order to reset the BIOS. Is there any way of confirming that I actually have B-die ram?
I used thaiphoon to look up the information but its just say 1die where it usually says B-die.
https://imgur.com/a/aINiPcn
MY-002-8P Description: Team Group 8Pack Edition 32GB (2x16GB) DDR4
PC4-28800C16 3600MHz Dual Channel Kit
Surely there's less requirement for higher ram speed with an X3D?I have had my 32gb kit a while now, but never had time to tinker with it.....until now.
I have this with a 5800x3d CPU - was hoping to get 3800mhz at cl14 from the ram, with 1900IF - however struggling to get there.
I can post with a lower IF (I was trying to keep it 1/1) - is there any downside to a lower IF with the ram at 3800mhz?
Thanks
