The AMD Driver Thread
Working like a charm for me, although I did have an issue in W11 where I had to use Vivetool to disable copilot otherwise Adrenaline just resets OC settings on reboot.
not bothered with this one everything is working like a dream so will stick to the last one
Like you I see no reason to update if everything seems OK but mine was still on drivers from about 5 months ago. I tend to stick with a quarterly or 6 monthly updates rather than with every driver.
Anyone using a 6900XT able to use FSR3's frame gen in the new Avatar game ? I'm troubleshooting a friends little HTPC he brought round to mine and every time I enable frame gen in game it comes up with a message saying a monitoring program is having issues with it yet there is no monitoring program of any kind running.​
Using the latest driver.​
Installed the preview drivers. Not really tested them yet but I did notice that the overlay doesn't have the option to show CPU temp anymore. Hopefully its just an omission from the previous drivers and not a permanent change.
i have it in the preview maybe you it toggled off? or you changed your settings not to monitor cpu
No, I noticed the option wasn't there when I was selecting what is show I in the overlay. I don't have any of the power stats for the cpu either, only option is to show frequency. I'll reinstall drivers later to see if I get the options back
I've had those turned off for a while as it wasn't reporting the sensors I wanted on my AM4 5900x. Adrenaline metrics CPU temp is pulling some average whereas I'd prefer Tctl/Tdie as that reads hotter. And the 'Peak clock speed' is the Effective clock, for me that isn't useful in games.
Is that the same for others?
Running the preview, CPU temp is working.
