Caporegime
- 7 Apr 2008
- Lorville - Hurston
OK I didn't know that but why would anyone buy from Asia paying import tax and delivery when you can buy locally in the UK and other countries?
I got my wheelbase and wheel rim from there. They had ample of stock compared to abruzzi at the time of orderingI bought from Race Anywhere. First time using them and great service. They’re not listed as a set so make sure you get all the bits you need
If its for PC use only I'd maybe look at the SimMagic stuff over those 2 options tbh.Any thoughts on Moza vs Fanatec for a wheel, wheelbase and pedals? Budget £700 max
Stories of poor Fanatec customer service is scaring me off them. Moza is prob more expensive and eco system less mature but it's more widely available.
Moza make decent stuff, not the flashiest or feature rich, but perfectly functional Entry/mid level parts and will give you a solid baseline to work with. I've had the R5 and currently use the R21, also the handbrake. A lot of reviewers have mentioned that the Moza software is falling behind a bit compared to competitors, but that dosnt mean it sucks, its regularly updated, just that the competition at the entry/mid level DD market is just so strong at the moment you can afford to be selective and the Moza software leaves a bit too much in the way of settings to the user. Better baseline settings would do Moza a huge favor.Any thoughts on Moza vs Fanatec for a wheel, wheelbase and pedals? Budget £700 max
Yes and yes.is there price inc vat? uk based shop?
