????I said "either end" IE front and back![]()
You posted :
CIG, just because it sits doesn't mean it fits....
You posted :
I'd just go head first! You know me by nowWell it is tight.... i'd love to see you try to squeze your connie in there.![]()
I'd just go head first! You know me by now![]()
Isn't it wrong orientation? Flip your ship by 90 degrees and it will fit.CIG, just because it sits doesn't mean it fits....
On a side note I just disabled the E cores on my 13900K, Holy crap the performance boost is crazy, The game is smooth as butter now, I did a few A/B comparisons and the E cores introduce a LOT of stutter.
I've disabled mine until there's a fix.
It seems that still being on Win10 is a big part of the problem in my case, as Win10 apparently doesn't really know what to do in terms of scheduling tasks and dumps stuff on the E-cores rather than P-cores.
The best fix is to use an amd cpuI've disabled mine until there's a fix.
The best fix is to use an amd cpu![]()
I was actually thinking of selling my 13900K, Mobo and memory and going for a 7800X3D but I'd still have to spend money I don't have.
Just run it with the E-Cores off, its fine.
The revamped turrets look spicyWelp.... that's that dealt with.
