- 20 Nov 2013
- leicestershire
I had the same problem with my cbr, it turned out to be a small stone that was jamming it up. I also had a similar problem with my zx636, that was the connectors that had corroded, all i needed to do for that was clean them up and it was working again, took me a long time to work out what the problem was though. Good luckI took my CBR600 for its MOT last friday... Gladly it passed
Only one problem... just as he finished the test it decided to wet itself all over the MOT testers floor
Turns out the cooling fan is seized solid so its not doing its job to cool the coolant... riding in the cold weather has kept me safe so far but leaving it running in a workshop with no airflow caused it to overheat and pop the pipe off the radiator.
somehow this is only an advisory
Looks like i'll be pulling it apart to replace the fan before i can take it out for a ride any time soon.
