£22.95 in that case! Just need to find it when it comes into stock!The Bilt Hamber website will have the RRP
It isn’t, but IMO there’s no value in buying an inferior product if you can just wait a little to buy the better one![]()
£22.95 in that case! Just need to find it when it comes into stock!![]()
I always swear by their alloy cleaner this is going to add to my car cleaning kit!Bilt hamber stuff looks expensive on paper but is very cheap per clean. The Auto-Wash is 1 tea spoon of liquid for 10 litres for example! A 5 litre of foam will last me 1 year easily and that is with 3 cars.
BTW Can I use this on my 530D alloys?
A year? I need 650ml snow foam per 1L bottle for 4% PIR, which lasts about a wash and a halfBilt hamber stuff looks expensive on paper but is very cheap per clean. The Auto-Wash is 1 tea spoon of liquid for 10 litres for example! A 5 litre of foam will last me 1 year easily and that is with 3 cars.
If you power wash first then the car is covered in water which dilutes the prewash. So generally, straight in from dry with the prewash or foam.So do I power wash first then BH Touchless, or just from Dry BH Touchless
I've started to this recently and it definitely seems to result in more dirt running off the car. Not sure if it's 'clinging' better to the surface or something but it seems to do the trick.If you power wash first then the car is covered in water which dilutes the prewash. So generally, straight in from dry with the prewash or foam.
So about 15 washes in total per 5L, which is half a year with 1 car or if I use to wash the Fiesta as well, 3 months.
How thick do you do it? I do 150ml of concentrate to 750 ml's of water in my lance. That is 33 bottles and a full bottle will do 2/3 cars for me so that is 100 car washes. I normally hand wash after so the pre-wash is just to get rid of 90% of the rubbish.
Decent set of brushes? For alloy, grills etc? There’s tons only but can’t comment
Thickness is irrelevant - it’s about the panel impact ratio (PIR)
AKA, how much product hits the car.
4% is roughly what BH recommend, and for me to achieve that, I’m looking at 650ml using a Karcher K5 and MJJC Foam Cannon v2 Pro
What is a good soft'ish brush for around badges (model number etc) ,or general small crevices near rear window seal, around wiper, grooves in lights.
found myself using a toothbrush at weekend - but a jumbo toothbrush would be great, google not showing me anything,
many years ago Australian friend left a toothbrush that must have been 30mmx10mm which would be ideal
Is that 650ML of BH Touchless to achieve that?
If so I’d be interested how 650ML of any other product compares performance wise.
Although I’m aware how economical you can be with a Foam Lance, it opened my eyes upgrading to Autobrite’s Foam Lance how efficiently it used product even on the highest mix compared to my previous eBay special.
