- 24 Jul 2009
Just had an email from them that says:My friend has just had a call from Lila to say that they are moving all customers away from static IPs (the select few that have them) and everybody will be on dynamic IPs, but with Open NAT.
"I am contacting you today from Lila Connect 2nd Line Support, we are currently changing how we deliver static IP addresses to our customers, at this time, your IP is set to STATIC and your equipment points to that IP address.
The process change on our end will result in your equipment requiring a reconfigure, to acquire IP addresses via DHCP.
The DHCP address we assign acts as a Static IP however, unless a change is forced on our end, it will not change.
If the new IP is needed for any configuration of equipment, we can provide it for you. Any previous Subnet mask, Gateway or DNS information will no longer be needed as the new DHCP address obtains these details automatically.
Whilst there is no deadline for this process change, If there is a convenient time for this change to be implemented, please let me know and we can schedule this for you."
So my IP address will still be static (unless it needs to be changed), I'll just need to change the configuration on my router to DHCP from static.
