Yes exactly, there are some things you just cannot reliably quantify, so cpu reviews in games wont show a full picture.At 1080 the gains I had was massive but not to the advantage fps. The stutter and lag is gone.
you're 100% sure that the sticks are in the correct slots? my current board, didn't follow intuition at all, the manual seemed wrong but it was in fact correct.( I have the X670E-A ,I'm going to try some new RAM, not because I'll get any benefit running at 6000 rather than whatever it is now but because I want to see if my MOBO (X670E-E) will actually allow me to boot using EXPO with a QVL RAM.
I didn't get a chance to game on the new system, but when I do I'll share what difference I think it's made.@Dirk Diggler just to double check that, so you're saying it was only a 2% from a 5900x to 7800x3d?
Bit rubbish if so and will likely stick with my 5900x...
ASrock B650m HDV here - super quick, below 20 seconds, in fact quicker than 13900k/z690 combo.What are people's boot times like, my boot and shut down is so slow.
Tempted to upgrade to the latest firmware, but doesn't seem to improve anything for some people.
Have the MSI x670e carbon. Read MSI don't have the best firmware?
Currently stable, so prob best just to leave it alone and put up with it. Just seems silly having a decent PC with super slow boot and shut down.
Do you have the memory checking feature on?ASrock B650m HDV here - super quick, below 20 seconds, in fact quicker than 13900k/z690 combo.
Yes, I have disabled memory context restore and its still very fast. Shut down not sure - I always leave the room.Do you have the memory checking feature on?
My shut downs can be longer than booting! Occasionally it's quick to shut down.
Boot is always a long time to post, then it's normal speed.
Its better to have it off - generally more stable to train memory each boot, but the downside is that it takes longer to boot.Is it degrading to the ram to not have it on?
I guess I could turn off anyway and see if it speeds up.
also, are you sure thart you are choosing the correct profile? I wanted to see if my current ram would do 6000mhz, and I ended up choosing the6000mhz x2 16 GB profile by mistake, idk if you have similar, but almost the same profiles, for rated speeds, at differing total amount of ram, worth checking!
Mine aren't as fast as my old am4 system that's for sure, even with a pcie5.0 m.2 but on the other hand things open within windows super fast, near instant for opening firefoxWhat are people's boot times like, my boot and shut down is so slow.
PC runs fast, that's all good. Why I haven't really been bothered, but it's been a few months and thought about it, that there might be some improvements.Mine aren't as fast as my old am4 system that's for sure, even with a pcie5.0 m.2 but on the other hand things open within windows super fast, near instant for opening firefox
if your boot times are stupidly long then you have to turn off boot memory training on every boot
it's called memory training restore or something like that, I think that it needs to be off.
My power button is set to switch off the computer in windows, and that is pretty instant tbh
I'm at 1440p with a 7900xtx and 5900x
Really want to pull the trigger but can't justify it with those gains
idk, but I doubt it is memory training on shutdown, are you on win11? AFAIK win 11 is slower to start up/shutdown, than win 10, I'm on win 10say 1 out of this instant shut down, the rest sit there, I can see some numbers on the mobo counting down, not sure if it does memory training when shutting down?
