Back in the days of yore I had an x800 pro that I happily unlocked to x800xt-pe spec. Would be nice if it was that simple these days, though I'd imagine the differing vram amounts would screw things up, unless the card still carries the correct amount for 7900xt.
Doubt it would be that easy.
Wouldn't try n flash 79GRE to 79XT.
Bios flashed unlocked 6950>70 in Crossfire then 290>290X bios mods were my BBFB ever.
And then on the 79 series, you worked out your max stable overclcock and created a bios to run it@stock!
Custom clocks/voltages you could apply to custom/water cooled 7950's back in the day-were insane, they were more more fun than the 7970's.
Now we undervolt.
This one right?
