Hopefully you don’t need to wait too long, i got mine well before they originally said.AW3225QF Ordered arrives in a couple of weeks.
Interesting, I was using creator mode with DCI-P3 but the brightness was on 75%. However when I switched to sRGB, I don't see the same behaviour, brightness level sticks.When it wakes up from sleep I think the colour space is in DCI-P3 mode for a few seconds before switching back to sRGB.
Check if your DCI-P3 mode is dark. DCI-P3 mode was at 10% brightness out of the box for me
Are power settings also locked down? Best way is to reduce screen turn off time in power settings.Going to get one as soon as codes are enabled.
Does anyone also use theirs for work? Is there an easy way to put up a full screen black image to save the screen? Cant use screen saver as locked down to corporate settings.
there was also a way to bind triggering screen turn off or screensaver via a keyboard shortcut, but I think that used a 3rd party utility so not going to wrok for you
PS. Oh yea, but just open a full black image full screen? I assume most image viewers allow it. Hell, open a black image in web browser and maximise full screen with F11
I use mine for work, yeah.Going to get one as soon as codes are enabled.
AW32 is awesome but I've gone back to my 42, just miss the size a bit too much (plus it gives me the flexibility of a 39" UW resolution when I fancy it). 138Hz combined with OLED responsiveness is still pretty damn good tbh, although the smoothness of the 32/240 is another level!Previous AW34 owners, still loving the aw32?
I've asked this before but now a few more people have these monitors, does anyone else see flickering on the desktop when using the 360 Hz mode with G-SYNC enabled? Do you even see this with FreeSync on AMD GPUs?
It can be quite distracting on my AW2725DF and G-SYNC does seem to otherwise work fine but the VRR flickering is a constant annoyance (as well as a reminder that while close to perfection that this QD-OLED still isn't quite there yet!) and I do not want to have to keep turning G-SYNC off and on. I was playing Alan Wake 2 over the weekend and the flickering was even visible in-game. It's already bad enough that I have to that for HDR for games and media content.
Seems the only way to reduce flickering in games is to have a consistent framerate but that kind of defeats the reason for using G-SYNC (VRR) in the first place for me. And I don't quite understand why their is flickering on the desktop wallpaper when there is no activity either but I can see it. I would expect the desktop at that point to be running at 360 fps on a 360 Hz refresh rate as I have an RTX 4080 Founders Edition graphics card.
Been experimenting on my 4k 55 oled and I think I could go back to 16.9 since larger screen does help with immersive side of things and DLSS performance/balanced does tend to look better than native/dlss quality 3440x1440, using DLDSR 1.78x helps bring the clarity to same levels but not quite as good as true 4k display. So annoying nowadays how the games assets seem to be of higher quality when loaded in with higher resolutions, it's almost like devs have some background configurations to detect what quality to use depending on what your resolution is set, I wonder if this is a leftover from console port configuration.
That's a good shout.You may have an app that is triggering the flicker on desktop. I have found 2 apps that cause the flicker for me: fancontrol and Razer synapse. Luckily the flicker is only there if I have either open.
Maybe worth trying to close programs one at a time and see if you can identify the culprit.
You can just switch it off in the OSD settings.today i got my aw3225qf! i noticed, whenever my screen is on, the power button is flashing white. it is a bit distracting, especially while watching movies. is that white flashing light normal?
It's the AW blue colour by default I think - and solid.today i got my aw3225qf! i noticed, whenever my screen is on, the power button is flashing white. it is a bit distracting, especially while watching movies. is that white flashing light normal?
