I don't think its £1508 a yearAnd then you’ll get taxed at least 20% on that and 20% when you spend what’s left.
£754 is the maximum per 2% point cutThat isn't correct as it only applies to lower band
Pensioners don’t benefit from NI cuts which is probably why it was attractive.There is no band with NI that's why tories like cutting it. Helps the middle.
ah the loony left, just as bad as the ridiculous rightedit - lefties are now moaning that its both too little and too much lol..
You have made my day!!! I honestly though it was £754 in total from last time too£754 is the maximum per 2% point cut
now if going from 12% to 10% = £754
how much is going from 10% to 8% going to yield...i'll give you a hint, it's the same as the above...£754
so £754 + £754 = how much?
another one that doesn't understand maths again @Mercenary Keyboard Warrior i leave him to you![]()
Do you have a link pleaseAccording to Telegraph its £1,320 saving on £100k from January and tomorrow's cuts.
Behind a paywall....
Cutting NI when the country (and the NHS in particular) is falling apart is a disgraceful move by the Tories.
Not really as more funding for public services does not equal better servive. Rather have the £££Cutting NI when the country (and the NHS in particular) is falling apart is a disgraceful move by the Tories.
I suspect the budget will take a lot of wiggle room away from Labour and is probably the intention. It was never going to be as simple as just bung tax on the higher earners to make up for it as they found out in the past when those policies lost them money.Shocking - luckily Labour will reverse it, oh wait..
