I don't think theres enough bandwidth on the GPU to simultaneously run 3440*1440 @ 240Hz (assuming a G9) and 7860*2160 @240Hz. They should both work at native res @120Hz.Hi, is there anyway to have the G95NC and a smaller uw (3440x1440) in a multi monitor set up. Whenever i try and use the second screen the G95NC res and refresh rates drops. Im using a 7900xtx/5800x3d
cheers
Same, got them in the states Amazon and UK on Samsung site.. but nowhere else... help....Anyone know why there is no sign of any stock anywhere for this monitor? Loads of reviews and discussions leading up to December.....then nothing.
Can you clarify why they can’t be used as two monitors? I’ve got a 35” ultra wide that runs two computers using the pbp (picture by picture is it??) without much issue, just planning on moving to a superwide g9 and this worries me as I use a desktop and laptop almost permanently.i would really get one if you could properly use PIP modes and it had more capability, but in the end these super ultra wides cant be used to act as if they're 2 monitors. just having a super long screen is a bit pointless.
also need DP 2.0 to become more mainstream
Still not entirely followingmain issue ive had is for example, if I had 2 screens normally I can watch youtube on 1 screen full screen and multitask on the other. However with ultrawides there isnt a clean way to watch full screen content on just half the screen - it will always just take over the entire screen.
.I'm considering one of these at the moment, anyone got any thoughts after owning one for a while?
I've ended up watching a few videos regarding the monitor, people are happy with everything for the most part, except the fact its not oled. Firmware updates only via USB apparently, lack of dp inputs if that matters to you, monitor sometimes going to sleep requiring a forced restart of your system to wake it up.Would also like to know how the HDR compares.
I am still using the original G9 that suits me fine for SD as the HDR is useless, I do use a LG C1 48 OLED for any HDR content I want to run.
Would love the best of both worlds, and still use desktop in SDR.
 I can always return it if I don't like it? right.I thought these were buggy AF? Did they fix a lot of it via firmware??
One thing's for sure, that resolution will give the 4090 a hell of a workout!!Currently can get it at £1606 + a free 32" basic smart monitor, I've got until the 19th before this offer goes away, the only one cheaper I've seen is an ex display model... so probably as good a price as I'll get it, unless it gets heavily discounted.
Yeah I think it'll be overkill at native, and probably not that enjoyable an experience in most games. I could be wrong though, I know whenever I upscaled cod to 8k it would drop me down to 60-80fps.One thing's for sure, that resolution will give the 4090 a hell of a workout!!
Ive had the original G9 for 18mo and this is exactly how ive used it 99% of the time, because its impractical for most tasks.main issue ive had is for example, if I had 2 screens normally I can watch youtube on 1 screen full screen and multitask on the other. However with ultrawides there isnt a clean way to watch full screen content on just half the screen - it will always just take over the entire screen.
I personally feel that it won't be a patch on the OLED model, but I hope I'm wrong for your sakeYeah I think it'll be overkill at native, and probably not that enjoyable an experience in most games. I could be wrong though, I know whenever I upscaled cod to 8k it would drop me down to 60-80fps.
