I said the other day that AMD has literally never provided a meaningful upgrade to FSR and HUB have just said the exact same thing.
Slightly annoying they didn't update the dll files for DLSS3 in some of those games though as soke were as old as 2.5.1 and DLSS quality control has improved a lot in later versions. It's a super easy drag and drop and something most people would easily do for the improved image quality and the comparison would be even better.
They should have mentioned this in the video as well that DLSS dll swapping is a thing whereas AMD don't support this and fsr updates require each game Dev to provide an update.
But apparently, it's such a hardship and pc gamers don't tweak settings
I'm so bored of these useless DLSS vs FSR comparison videos. The situation hasn't changed in years, and nor will it until AMD fundementally change the way FSR is developed. Which will no doubt be something they announce, so why do we need these constant check-ins other than the purpose of feel-good clickbait for Nvidia owners?![]()
AMD MUST Fix FSR Upscaling - DLSS vs FSR vs Native at 1080p
Thermal Grizzly: https://www.thermal-grizzly.com/en/kryosheet/s-tg-ksSupport us on Patreon: https://www.patreon.com/hardwareunboxedJoin us on Floatplane: htt...www.youtube.com
Pretty factual but brutal conclusion by Tim.
What does this even mean? Nvidia provide the dll files to devs for new games coming out when under development, the dev then ships that version they used in the release of the game.It’s on nvidia to figure out how to ensure the latest version of DLSS is being deployed widely. No need to make excuses for them
XeSS is better than FSR in basically every game that features both upscalers as an option. XeSS works on any card too. Just the only issue is XeSS needs to be supported by a game first.The issue is all these reviewers are completely clueless and just yap stupidly & incessantly. Ofc FSR hasn't seen improvements... because there's no improvements to be had. It is the best vendor-agnostic TAAU solution available already, and where it is aced it is done so through a LOT of speed-ups from hw acceleration for the clamping step, which is the only real fundamental difference between all the vendor TAAUs (hence why you see ghosting/shimmering much improved in DLSS/XeSS XMX). So the only solutions available are either you spend a lot more ms to improve that step (you see this with TSR, but also in XeSS's DP4A abysmal performance and with no real notable improvements, just different IQ trade-offs) at which point you might as well just run TAA because it will be better, at least at lower res where the upscaling trade-off isn't worth it; or you have to introduce hw/acc - which is why you also see XeSS XMX is close to identical to DLSS, because there's no magic model for DLSS that makes it the bees knees, it's simply a function of the HW doing that step really fast. So then why isn't AMD doing it? Simple, because these hardware changes take years to plan and execute and they're unfortunately still reliant on making major arch changes around consoles.
Tbh instead of crying about AMD these ppl would do better to pester the devs which implement all these solutions very poorly, failing to even adhere to the implementation guide's simple steps (f.ex. lod bias mismatch, masks etc.) There's already plenty of IQ improvements that could be had but are missed because they won't do the work required.
The stuff about XeSS really isn't accurate. It looks much better than FSR even running on an AMD/Nvidia card. I'm yet to see any evidence that there are image quality compromises in running it on an AMD/Nvidia card as opposed to Arc. The compromise comes in terms of getting less of a performance boost due to it needing to take up shader resources, but in my experience testing it on non-Arc cards, XeSS in Balanced mode looks significantly better than Quality FSR whilst performing close to it. As a result, it's the best upscaling solution available for non-RTX cards and very close to DLSS these days. I'd take it over FSR every time as an AMD/GTX user. Which also rather dismisses the argument that there's some special hardware component needed to make upscaling look good. People keep parroting the Nvidia marketing spiel that DLSS is only possible on RTX cards due to the awesome power of the tensor cores, and yet DLSS 1.9 (the first "modern" version of DLSS and a prototype of what we have now) ran on the shaders - just as XeSS does on AMD/Nvidia cards now. The hardware component on the user's end simply accelerates the performance of what is inherently a software solution. That isn't to say there aren't benefits to having dedicated hardware to offload it to (you get both the image quality AND the biggest performance uplift), but it's just not true to say you can't have DLSS-like image quality without dedicated hardware. You can. I've seen it with my own eyes running XeSS on a non-Arc card. The key to it all is the work that's done on the Intel/Nvidia side with deep learning. There's no reason AMD can't do that as well and provide an XeSS-like solution, which would look much better than FSR does now.The issue is all these reviewers are completely clueless and just yap stupidly & incessantly. Ofc FSR hasn't seen improvements... because there's no improvements to be had. It is the best vendor-agnostic TAAU solution available already, and where it is aced it is done so through a LOT of speed-ups from hw acceleration for the clamping step, which is the only real fundamental difference between all the vendor TAAUs (hence why you see ghosting/shimmering much improved in DLSS/XeSS XMX). So the only solutions available are either you spend a lot more ms to improve that step (you see this with TSR, but also in XeSS's DP4A abysmal performance and with no real notable improvements, just different IQ trade-offs) at which point you might as well just run TAA because it will be better, at least at lower res where the upscaling trade-off isn't worth it; or you have to introduce hw/acc - which is why you also see XeSS XMX is close to identical to DLSS, because there's no magic model for DLSS that makes it the bees knees, it's simply a function of the HW doing that step really fast. So then why isn't AMD doing it? Simple, because these hardware changes take years to plan and execute and they're unfortunately still reliant on making major arch changes around consoles.
It's a shame they didn't test NMS. IIRC the switch version with FSR was very well received and AFAIK they ported the work they'd done for switch to other platforms. It does make me wonder that if Hello Games managed to implement FSR as well as they have are the issues we're having with FSR just technical or also down to the devs too. Not that that makes a difference from a players perspective - a crap image is still crap regardless why.![]()
Incorrect.XeSS is better than FSR in basically every game that features both upscalers as an option. XeSS works on any card too. Just the only issue is XeSS needs to be supported by a game first.
It doesn't. It has different trade-offs in terms of ghosting vs shimmering (as well as different artifacts/visual bugs - f.ex. been testing Cyberpunk again lately and spent considerable time with XeSS and saw visual glitches that simply aren't there with FSR, such as rain puddles being a complete mess in motion like a weird soup, the vegetation in Northside shimmering horrendously during daytime, the LODs during outdoor cutscenes going haywire, which was the case ever since they introduced XeSS etc.), and on top of that it has much higher performance penalty.The stuff about XeSS really isn't accurate. It looks much better than FSR even running on an AMD/Nvidia card.
The DP4A looks the same on all. That's now what I'm talking about.I'm yet to see any evidence that there are image quality compromises in running it on an AMD/Nvidia card as opposed to Arc.
The compromise comes in the form of what AA weakness you focus on, as I've said above, XeSS allows more ghosting but will see less shimmer/edge aliasing compared to FSR 2, but the later will have a more stable "clamping" of the image overall. More importantly this is not really a difference between the two but rather a choice (for the devs) - you can setup FSR2 like XeSS as well (or vice versa).The compromise comes in terms of getting less of a performance boost due to it needing to take up shader resources, but in my experience testing it on non-Arc cards, XeSS in Balanced mode looks significantly better than Quality FSR whilst performing close to it.
But it's not, because again - different trade-offs and on top of it, the coup de grâce is that it has much heavier performance costs, and that's what kills it. For low-end cards - it's DOA. For mid-range, it becomes usable but it's really only a question for AMD users. For high-end, only NV has such cards (so you use DLSS because it's the best). So who does it actually benefit? And that's assuming you'd want the ghosting and visual bugs of XeSS over FSR's ones.As a result, it's the best upscaling solution available for non-RTX cards and very close to DLSS these days.
Feel free. A lot of the IQ differences come down to subjectivity anyway (tho ofc not the performance).I'd take it over FSR every time as an AMD/GTX user.
Evidence? I/we have all played the games using all 3 tech, and FSR always falls behind, always. Even in games that are AMD sponsored, FSR is behind.Incorrect.
drive.google.com
drive.google.com
@mrk You would have done better to read again for comprehension. I explicitly talked about issues in motion. Who even tests static scenes with TAAUs? Completely pointless.
How FSR is superior to XeSS to how it handles vegetation [for this one wait for 4K to process, can't see it otherwise - or better yet, go test it yourself and verify]:
R2.mp4
drive.google.com
Or how some issues that exist even in TAA are then exaggerated with XeSS but get suppressed better with FSR (and this is corollary to the visual artifacts that then pop up in certain quest scenes with only XeSS as a result; repeatable in the Q for Meeting Oda, or 6th Street with Panam etc.):
R1.mp4
drive.google.com
I wish I had a rain scene too, because that's the worst of the bunch, and that's where XeSS is just dog doodoo. Alas, you'll have to make do with these.
{edit- Similar issue but with reflection:}
I can promise you, there is no one that's spent more time testing Cyberpunk than me, and I've actually played through the whole game with these things, all quests & gigs (and every game version since 1.0, so I know how they all act and how they've changed). Actually playing, not photo mode-ing or superficial testing for the random youtube "tech" channel. That's why I'm the only guy you know who's pointed these things out. And if you had done so too then you wouldn't argue with me about what are obvious differences between these TAAUs.
I’ve started playing CP so would really appreciate any settings guides/summaries you recommend or can share because I’ve got mine running pretty much how I want it with path tracing/RT enabled but more by trial and error/blind luck than anything else.@mrk You would have done better to read again for comprehension. I explicitly talked about issues in motion. Who even tests static scenes with TAAUs? Completely pointless.
R2.mp4
drive.google.com
R1.mp4
drive.google.com
What's your system and resolution/hz? Tbh if you're doing PT then that must mean you're on Nvidia, so nothing beats DLSS. With PT (or RT) there's also not much you can do to really "optimise" it further, outside of mods, mostly just setting volumetric clouds & fog to medium, or turning down Crowd Density if your CPU is holding you back. In terms of RT it's really down to three choices. If you want it all, if you want Lighting (Medium for AO, or Psycho for GI boost), or if you want Reflections. Sun Shadows & Local Shadows have very little performance cost once RT is already engaged, f.ex. if you want Lighting or Reflections, so I'd always have them on.I’ve started playing CP so would really appreciate any settings guides/summaries you recommend or can share because I’ve got mine running pretty much how I want it with path tracing/RT enabled but more by trial and error/blind luck than anything else.
I accidentally put FSR on yesterday while experimenting and was confused by the glitching with wire mesh fences and some reflective floors. This stuff is all new to me so could just be my incompetence.
Don't laugh - I'm still dithering over a new monitor at the moment with a view to going 1440p, possibly UW, but for the moment it's just 1920x1200/60Hz. It's obvious that my CPU is bottlenecking as the GPU is only showing about 40% usage at times. I'd like to play with DLDSR for gaming but if you don't have a 16:9 monitor it seems you're stuffed (DLDSR and DSC are not helping me right now given current manufacturer design choices).What's your system and resolution/hz? Tbh if you're doing PT then that must mean you're on Nvidia, so nothing beats DLSS. With PT (or RT) there's also not much you can do to really "optimise" it further, outside of mods, mostly just setting volumetric clouds & fog to medium, or turning down Crowd Density if your CPU is holding you back. In terms of RT it's really down to three choices. If you want it all, if you want Lighting (Medium for AO, or Psycho for GI boost), or if you want Reflections. Sun Shadows & Local Shadows have very little performance cost once RT is already engaged, f.ex. if you want Lighting or Reflections, so I'd always have them on.
With mods, I'd recommend Ultra+ for RT/PT optimisation and HD Reworked Project for textures. Outside of graphics I personally consider mandatory AutoLoot (huge QoL improvement), Missing Persons (should really be a part of the game almost, it's that good and perfect for if you like losing yourself into the game further lore-wise), and Better Vehicle First Person (it makes actually driving in FP a joy now).
Thanks although I can't see those in path tracing in my game, plus my screenshots are not taken in photo mode, I have a toggle hotkey to vanish the HUD and that's what I used for the samples I posted. But yes in motion I wouldn't have seen anyway as I didn't test for in motion with the other upscalers generally speaking, DLSS FG/RR is my main use case so that's what I've been focusing on and that's where the full quality is.@mrk You would have done better to read again for comprehension. I explicitly talked about issues in motion. Who even tests static scenes with TAAUs? Completely pointless.
R2.mp4
drive.google.com
R1.mp4
drive.google.com
drive.google.com
drive.google.com
drive.google.com
