Yes. What do you need to know?Has anyone had both the 360hz 1440p and 4K 240hz monitor side by side?
It'll be too smol for you, I guarantee it.tempted to buy the 27" model just because I can have it to play with by the end of the week.
The increase from 240Hz to 360Hz is pretty small, maybe relevant if you're a serious or competitive gamer and are chasing best motion clarity, frame rates etc. I think the increase to the 4K resolution and the larger screen size of 32" is more beneficial to most peopleWhich one would you buy if you had to choose between the two, is the step up to 4K more important than the 360hz refresh rate?
although i didnt noticed anything wrong with the monitor, this error message popped up. any ideas why this happened?
How do you get the 5% code, all the usual blue light/nhs/uni days didn't seem to work
I'm not upto date with current monitor specs, however at work I plug my keyboard/mouse into the screen and my laptop into the usb-c and I can use multiscreen that way. Does the usb-c port on this screen work in the same way?The increase from 240Hz to 360Hz is pretty small, maybe relevant if you're a serious or competitive gamer and are chasing best motion clarity, frame rates etc. I think the increase to the 4K resolution and the larger screen size of 32" is more beneficial to most people
see my review here: https://tftcentral.co.uk/reviews/dell-alienware-aw3225qf
I'm hoping to share a keyboard/monitor at home with my gaming pc and work laptop for ease and by only needing to plug the usb-c in to switch
Apologies for the basic question but until recently I'd never made use of the usb upstream on a monitor!
Ah OK, that answers that question then! What should I be looking for in the specs to see if this is supported? When I say connect both I mean to only use one at a time, just the ease of leaving my main pc hooked up with just an upstream to share the keyboard/mouse with the laptop just using a usb-c to the monitor is so handy for working from home.No KVM with this.
Are there any alternative 32 4ks oleds out that can do this that you know of?
You would need a KVM switch built in to the monitor as stated, but you’d also need the screen to support a USB-C port with DP alt mode for video and power delivery to charge your laptop. The Dell AW3225QF doesn’t have either I’m afraidAh OK, that answers that question then! What should I be looking for in the specs to see if this is supported? When I say connect both I mean to only use one at a time, just the ease of leaving my main pc hooked up with just an upstream to share the keyboard/mouse with the laptop just using a usb-c to the monitor is so handy for working from home.
Its not ABL, but rather Multi Logo dimmingI have noticed a moderately distracting issue with the Netflix app when using it on my AW2725DF with the Standard profile SDR mode which at first I thought was flickering. It isn't is related to the use of subtitles where the screen noticeably darkens when displaying the (white) subtitles then brightens slightly when they disappear until the next subtitles appear then the screen darkens again. I thought this had a stable brightness level when using in SDR mode but what I am seeing appears to be the ABL (Automatic Brightness Level) doing its thing. This was seen while watching the awful remake of Firestarter by the way, again in SDR not HDR.
Am I wrong here as I haven't noticed ABL in games even though I also play those with subtitles enabled?
described hereActually clarified on the next review
There is no option to disable it on AW, but supposedly its not active in Creator SDR mode
Ah damn that sucks, I nearly ordered it as well! I take it none of the Alienware oleds offer this?You would need a KVM switch built in to the monitor as stated, but you’d also need the screen to support a USB-C port with DP alt mode for video and power delivery to charge your laptop. The Dell AW3225QF doesn’t have either I’m afraid
