I’m struggling so much doing this plan outdoors.
How did people train before turbo trainers were a thing lol
Wait until you see the turbo training people like Graeme Obree used to do. On what would now be a £50 exercise bike sitting outside for the cold and just starting at a wall 6 foot in front of you for hours.
It's not even the boredom part. It's the watts. I know riding outside is easier than indoors but the gulf between the two is pretty stark
As an example. Yesterday my sweet spot ride wanted me to target 190w. Indoors that would be 'easy' thanks to ERG keeping you honest but at my level it would also feel like a decent effort. Outside I just couldn't do it. So I ended up doing 230-250w. Whereas doing 230-250w indoors would be challenging.
Maybe I need to look at the cooling in my shed as I only have a headwind fan and maybe that's the cause. Just seems wild that holding significantly higher watts outside is significantly easier.
Either way, I'm going to be in for a rude awakening when I get my Kickr back
Yup, I struggle with that and really can't do low power standing!Yup, high cadence and low power I fail every time. Even in ERG mode.
Magnesium tablets? take one each morning. I tried it a few years ago and cramps vanishedOk advise needed, as im getting in to slightly longer rides (tipping over 1 hour now) im starting to get occasional calf cramping, is this potentially something i can combat with electrolytes?
Could your bike fit be contributing to it, e.g. cleats too far forward?Ok advise needed, as im getting in to slightly longer rides (tipping over 1 hour now) im starting to get occasional calf cramping, is this potentially something i can combat with electrolytes?
I have run out so will get ordering.Magnesium tablets? take one each morning. I tried it a few years ago and cramps vanished
I feel quite comfortable on the bike, ive always had quite tight calfs and its just after longer stints. Maybe its saddle height i only got the issue after raising it 10mm but due to odd proportions if i didnt do this i had to sit so far back on my saddle for the stroke to be comfortable. Cleats are actually as far back as they can go already.Could your bike fit be contributing to it, e.g. cleats too far forward?
i mix a high-5 tablet or two into my water - https://www.amazon.co.uk/HIGH5-ZERO-Pink-Grapefruit-8x20/dp/B007PF8HHG?th=1Ok advise needed, as im getting in to slightly longer rides (tipping over 1 hour now) im starting to get occasional calf cramping, is this potentially something i can combat with electrolytes?
You sound pretty similiar to me tbh, even same weight. I'm down to 75kg but I'm 6 foot 3. How do you feel about your top end power from doing all the base building? I was concerned but after getting back from Majorca from 2 rounds of base, I was smashing out some big watts with a relatively low HR for me.Solid effort!
I've paused my Zwift subscription for a few months. Probably return to it after the summer but I'm keen to give ADZ a go especially after I finish my TR plan.
I'm midway through Base Building 3 then I start my 'sustained power build' weeks. For the speciality phase I originally picked 'rolling road race' but I've changed that to 'climbing road race'. As someone who'll probably, at best, be about 75-79kg (which still puts me at an overweight BMI lol) I'm never going to prosper as a climber but I just enjoy climbing so I'd like to get stronger there as I'm pretty weak at it.
Will be interesting to see what my ADZ time will be once I've done my first proper structured training plan. Think my current best time is 75 minutes and I set that quite a while back so if I can get to the high 60's I'll be really happy.
I've gone from 1.68 w/kg to 2.59 w/kg. Still pretty low and I expect it's mostly come back as just spending more time on the bike. It's 3.2 to do the alpe in an hour so that's been my goal for a while
I've semi given up on TR now and I'm roughly doing long ride, then high intensity rides on rotating days.
Hoping to start doing extra long rides outside again soon too, as 3+ hours on a trainer is getting harder to motivate myself to do.
