Finally received my NR200P MAX but not from OCUK
As you can see below it fits a 4080 FE perfectly and with a ModDIY 12VHPWR custom cable looks very neat. Of course I couldn't just do a fit and forget as that's quite easy in this case with the pre-installed AIO + PSU.
So I ordered an ASrock Z790M-ITX WiFi motherboard with eDP port and an Asrock 13.3" LCD panel kit.
Your processor must have an iGPU as the eDP port uses this to drive the "internal" LCD panel. Very important to remember that as it's not clearly stated from what I remember.
Temps are fine with a 4080 FE. I have 2 top 2 bottom exhaust fans. Plus the PSU is drawing air directly away from the FE rear exhaust fan. 50C in normal gaming and 60C when running Superposition 4K Extreme bench. My 4080 FE does have a mild undervolt applied which keeps power down to 270W or below most of the time. Very quiet even when running a bench.
