Mrs TB decided that today I would
Either works. Im with @Buffman though and prefer to fit the bath first and tile from it.
Bath first, fill, silicone etc. Also can use a classiseal this way.
You can't use it the other way, it creates a tileable lip and has be installed behind the tiles. It's really neat, same with shower trays.Isn't that a pain in terms of having to stand in the bath to tile? Also potentially risky if you drop tile on to bath.
Why can't you use classiseal the other way?
I can see why bath first is good though, a solid/known base to tile from.
I'd assumed when installing bath afterwards the idea is to start tiling from the 2nd row onwards then installing bath before putting the final/first row of tiles on.You can't use it the other way, it creates a tileable lip and has be installed behind the tiles. It's really neat, same with shower trays.
Fitted the basin waste that I ingeniously managed to lengthen several weeks ago.
Completely guessed where to leave the basin waste in the wall before plastering and you can see it was about 3 inches too low. So cut up the spare U bend and made a collar to sit inside the two pieces where the basin and U connect.
An awful lot of silicone holding this together first fit about a month ago seemed to want to leak a lot.
How come you didn't put the bath in before the tiles? Normally you would do that then put a seal /tape from the waterproof wall boards to the bath then tile on top?
I don't think it will matter 100% as you can pump it full of silicone when you tie the bath to the wall (make sure to sit the bath on battons!) then put silicone on the bath/tile interface.
Looks like you might be struggling on that niche to get a trim up to it but I'll wait and be proved wrong! Speedy work
As I also thought and the way I've always done it.
Do You Fit A Bathroom Suite Before Tiling?
Planning to renovate your bathroom and wondering if it's best to fit a bathroom suite before tiling or vice versa. Read our blog to learn about the ideal sequence for a quality finish and water damage prevention.www.bathroomtakeaway.com
Definitely prefer to put bath in first, but I was up against it and knew it'd be "significantly" more annoying to have the bath in place (I was doing floor and walls simultaneously), so I did throw the dice on the marble being bang on for the bath to "butt up" against. I've left the green so I can cut into the bath/tile down, and the final piece of marble will lock it all together. So I'll probably Classiseal just those bits; so at least the corner/"wettest" bit is belt and braces.Isn't that a pain in terms of having to stand in the bath to tile? Also potentially risky if you drop tile on to bath.
Hah, thanks man - however I started Jan 16th and my original plan "1930s refurb" thread was 18th August 2022@dlockers you work quicker than the pros!
Is that going to be fiddly to maintain? Not that there's much maintenance required.
I like it. What did you use as I need to redo our picnic bench and thats the exact colour I'm after?
Not really, it'll already have 4 legs to do that... But I've always battened the wall out and supported with timbers at the front as well. I actually pity the person who tries to rip out one of those.Final fix bath (is it worth putting a plank on the floor to distribute the load from the marble/hardibacker?)
Thanks -- I'll batten the wall and I did buy some CLS to batten the front out too but used it for the tile batten. A trip to Wickes is in order anyway as I ran out of adhesive again lol.Not really, it'll already have 4 legs to do that... But I've always battened the wall out and supported with timbers at the front as well. I actually pity the person who tries to rip out one of those.
Good progress, why didnt you remove the architrave and tile underneath it. Also looks like you avoided that horrible slither on the niche... good stuff. Green tiles on the back of niche will look good.
