Probably not but if only ofgem would say why it varies so much. They're just deliberately vague I feel.Is it fair that areas should have different SC costs or even Unit Costs? If yes, why?
dude you argued before that "national grid" therefore different prices are not fair. Can you not see the double standards here?Because his standing charge has nothing to do with having a turbine nearby?
'Dude' I literally said it was a national grid in reference to national grid infrastructure, your connection to the grid is maintained by your DNO so costs are dictated by them.dude you literally argued before that "national grid" therefore different prices are not fair. Can you not see the double standards here?
IF you have a turbine generating power less than 1km away from your pad, then it stands to reason that it is a lot simpler a job to get that energy from the turbine to a few km away to the local vicinity rather than sending it to the opposite end of the country.
I think its a difficult sell to say national grid should pick up the costs of the large stuff and share it equally when from what I can tell the large works are really supporting just the south east and london.
Eg like I said the local conversations about the major works required to send the local off shore down to London from my area.
We all need to pay for the national level infrastructure that helps the south east/london, but we should pay locally for local distribution and benefit those in large areas with no/limited generation.
I means its 100% cake and eat it stuff. Brexit levels of honesty![]()
I guess obvious issue that you cant really build the infrastructure in or around London and the South East except onshore wind which is basically banned in England. I mean where where would you put a nuclear plant or a wind farm in London, offshore wind around the Solent, Dover and the Thames estuary, is a bit of a no, no also.
I agree, and I am in a low SC area, so if it was implemented I would actually lose out. If anything its getting worse as certain regions are now getting free energy occasionally instead of spreading that cost benefit to the entire grid.The difference between London and Scotland is circa 50% MORE in Scotland than London.
I aint even arguing for it to go the other way (following your example above) - I just think SC should be the same throughout the UK. At the moment, the "energy powerhouse" areas of the UK are subsidising the other areas and the argument for this difference - "distribution costs are more due to lower density/more difficult areas to run infrastructure to". no one is even looking at the fact that these very same areas are disproportionately producing the energy compared to the lower SC areas.
Unless they are also funding them, why?I believe the government were talking of having some kind of localised price impact for future on shore developments.
In fact on googling the link there are some more schemes that exist, such as
It's like some admission that an 'eyesore levy' is needed because people don't like them.
I'm not seeing what impact they have apart from looking at the things.Its not a eyesore levy its a we need to make progress here and create a position where those impacted gain some benefit.
Seeing as we all agree we are not going to be scattering nuclear plants, wind turbines and solar fields all over London it seems sensible that those who need to be impacted see some benefit as well.
Where I am there's some kickback because they are building a solar farm all over prime farming land. I'm sure someone is making money though. Personally I don't care too much as, like wind turbines it's the future, although it does all look a mess. Certainly there's some NIMBY'ism going on with this stuff.I'm not seeing what impact they have apart from looking at the things.
I'm sure there is. So if the reason local people should get some discount is because of visual impact people should just be honest and say it.Where I am there's some kickback because they are building a solar farm all over prime farming land. I'm sure someone is making money though. Personally I don't care too much as, like wind turbines it's the future, although it does all look a mess. Certainly there's some NIMBY'ism going on with this stuff.
which is precisely why having localised, relatively small generation is surely better.doesnt the grid need to be load balanced? and also kept within frequency, thought that would require a lot more infrastructure to keep things from going pete tong and major transformers from blowing up (which take years to replace afaik).
