On Android you can easily check recent component access history from any apps that used mic/camera etc. It should be really quick and easy to actually see if any of the apps on the phone used the mics to listen during that work period. Android now also notifies you if an app uses the mic or camera in the background. This is part of the security measure brought into place since Android 13/14 if I recall. The default permission for accessing these features for any app is to prompt the user to either allow always, or only whilst the app is in use, or deny entirely. You can check these in app permissions from within Android Settings.Well yes, this is well known. Do you have Facebook or WhatsApp installed on your phone? Do you have the microphone enabled for either of them?
if it did not, then it's a simple case of the algo putting two and two together, someone in that office at one point or still does, a connection between the two people and the algo has recognised this past connection and has probably targeted Nitro PDF ads to all parties involved to accounts it has seen as related.
