It just a C++ project I have done, went through a YouTube tutorial and then extended it.What app is that?
Tutorial is here:
Ah, was just going to give it a go if was a simple download = run. Seems like too much effort for me.It just a C++ project I have done, went through a YouTube tutorial and then extended it.
Tutorial is here:
If you know somewhere I can upload it without creating an account, you can try the release build.Ah, was just going to give it a go if was a simple download = run. Seems like too much effort for me.![]()
Quickly ran it and saw 53-54MS. Is it purely a CPU test?If you know somewhere I can upload it without creating an account, you can try the release build.
see if you can beat 60ms per frame
edit:
its here if you want to try it: https://easyupload.io/ea6fg9
Yes, CPU does all the work. Uses Vulkan to display the result. I get 60-62ms but am using ECO 65W. Need to add special partitioning so I can load better scenes.Quickly ran it and saw 53-54MS. Is it purely a CPU test?
AMD Ryzen 9 9950X CPU tested: Zen 5 chip is 46% faster in Cinebench R24 than Ryzen 9 7950X
AMD's next-generation Zen 5-powered Ryzen 9 9950X processor: 16-core, 32-thread Zen 5 chip is 46% faster in multi-threaded Cinebench R24 benchmark.www.tweaktown.com
Cleaely someone's just taken the 7000 series scores and added ~40% to them. If only!![]()
Why not? Ryzen 1800 was in Cinebench R15 about 65% faster (single core), than FX-8350, if I recall correctly. 7700x vs 5700x is over 30% jump in single core in Cinebench R23 and about 45% in multi core. If they made some big changes to the Ryzen core again, ~45% isn't even that big of a jump, we've seen bigger in the not so distant past between generations. Seems very plausible to me, actually. The question I would have is - how much power was used by it with that performance? It's not that hard to make fast CPUs these days, it's hard to make them not guzzle down a small powerstation whilst achieving high scores.That's a 46% gain... yeah right.![]()
./FX-8350
If we see 40%+ anywhere it's going to be some specific (probably AVX-512) workload or something. Expecting 15% IPC + 5% frequency
It's been a persistent rumour for around a year now that ALU count of Zen5 is going up by 50% from 4 to 6 ALUs per core, so in raw performance that's a 50% increase. In reality, it could be more like the 20-30% rumoured depending on workloads, and the ones that are really ALU bottlenecked might see the full 50%. Excavator to Zen1 was a 100% increase in ALU from 2 to 4 which netted a ~40-50% increase in IPC, of course AMD might have learned a few things since then and the Zen5 architecture could be much better suited to take fuller advantage of the ALU increase than Zen1 was.I think we’ll be lucky to see +20%.
Hoping zen 5 ipc to be 2x my 9900k as it’s definitely holding back my 6950xt at 1440p 165…
