- 14 Aug 2009
There's so many logical mistakes there!With these settings the 7900 GRE is around 60 FPS, the thing with that is now so is the 4070, its no longer 40% ahead, its now less than 10%.
For a lot of these mainstream tech jurneos that's not the correct narrative, bigger bar better, the trouble with that is bigger bar is 27 FPS on a £600 GPU, so no one who understands the value of money gives a ####, because its all just ####, so all they care about is other things that are not RTX.
I don't care about RTX in Cyberpunk, at all, because i don't have £1000+ to spend on a GPU and because Cyberpunk just seems to be all about RTX i don't care about Cyberpunk either, even knowing its not all about RTX, i'll wait for it to land in the £4.99 discount bin, even then i'm still like: is there anything else for £4.99?
It just puts me off it....
You're complaining that some journalists don't test for a specific set of settings, at a specific resolution where the cards are close enough and by that they're constructing a narrative, when you're doing basically that exact thing -> playing with the settings to suit your point!
) And nVIDIA is still cheaper than AMD. Sorry.Moving on, you seem to be upset that some high end, groundbreaking game(s) require the best hardware out there (story almost as old as the gaming itself), that you can't afford, a game that you may or may not like - is not clear by your wording and yet... here you are (!), discussing something that apparently you have no interest in, but you want that lack of excitement to be imposed on others as well. They can't be possible enjoying RT and PT, right?!
To be clear IMO these Cyberpunk charts give RT a bad name, because 97% of gamers don't buy £1000 GPU's and it just perpetuates the idea that RT is for the ultra elite among the PCMR community only/
Its very exclusive.
And 97% of the gamers don't have a 4k screen that requires a 1000 pounds GPU. Heck, I use the 4080 to play at 1080p, too!
