Caporegime
- 30 Jul 2013
Most things are watchable if you don't actually watch themit's watchable if you put it on in the background while you spring clean. Solid 5/10.
If you mean Walton Goggins, then yes.Is that guy with no nose the same guy from maze runner 3?
Much like your posts, they are background entertainment, largely works of fiction. Solid 5/10it's watchable if you put it on in the background while you spring clean. Solid 5/10.
I tend to make dinner and such when watching some shows and I would suggest this isn't a good show for doing other things. Part of its appeal is its visual element.it's watchable if you put it on in the background while you spring clean. Solid 5/10.
It's literally set in a waste land or an anonymous vault it gets samey very quickly.I tend to make dinner and such when watching some shows and I would suggest this isn't a good show for doing other things. Part of its appeal is its visual element.
We're going to have to agree to disagree.It's literally set in a waste land or an anonymous vault it gets samey very quickly.
The only visually bad bits are the desert bits
I love the games, and loved this too. 8/10 for me.Just finished it. On the whole quite good. I'm sure I missed loads of stuff by not playing the games, but the story was good enough that I don't really mind.
Still quite a lot of questions to answer, but reading online season 2 was already confirmed on April 18th (even before I started watching!).
Definitely a 7-8/10 show, which I will definitely re-watch prior to season 2.
Maybe I should go back now and try other shows where I skipped them cos I hadn't played or enjoyed the videogame....Halo, Twisted Metal, The Last of Us are recent ones I can think of.
rp2000
Might have to try this one next asStart with The Last of Us, it's fantastic.
