- 20 Jun 2023
- uk
Wiped some bird crap off it.
Hopefully sorted out a leak on the Mrs' Focus. Rear bumper off and sealed the stupid vent flap things that leak. Also sealed the top panel section near the boot hinge.
Will see how it goes now but I used my vax carpet cleaner to sack up as much water as possible and nearly got a full tank from the drivers and same side passengers footwell!think it's about 2 litres.
Taxed my M3 before a track day next week as it’s not been driven since November. Drive it get fuel and parked up but the next morning after moving off the drive I heard a noise, turns out the spring snapped and then rubbed on the tyre taking it out. Seems they don’t like sitting. Just fitted H&R sport lowering springs which is a small drop over the competition pack.
New brakes will be needed after the track. Disks are still silly money on these at £600 a pair OEM
Also removed the pins to allow max front camber on both sides
Job well done. Super common on a focus. I've done mine before.
Also If you ever have to do it again. Behind the vents, the further back ones there's sound deadening in the void behind them. Problem is.... These act like a sponge, fill up and dump the water inside. So remove them if you get any more issues, belt and braces.
I'm sure what you've done will have sorted it. It's just if it reoccurs.
There's also a couple of rubber drain plugs you can remove from underneath the bumper that helps remove any water that unfortunately makes its way in.Also If you ever have to do it again. Behind the vents, the further back ones there's sound deadening in the void behind them. Problem is.... These act like a sponge, fill up and dump the water inside. So remove them if you get any more issues, belt and braces.
Yeah man. The amount of smoke just going 40mph was insane. Luckily I realised what it was when I stopped and limped home. A total of 2 miles and the tyre popped as I pulled onto the drive.Good job that didn't happen on track![]()
That's good going for before 10am on a bank holiday!Well, put a load of sound insulation in the doors to help my music from sounding boomy and it's worked a treat, dirt cheap to do and although a bit fiddly getting the door cards off without breaking anything... worth while. Also bit of interior detail and get presto another 40bhp there...
Now to find something else to do...
Green means go as my driving instructor used to say.One woman in her Smart car, who admittedly did have the green light on a pedestrian crossing, literally pushed a group of teenagers out of the way with her car.
(Although you can guarantee that it runs straight down your arm when you do remove them)
