Black hoses everywhere, paint the cutesy wutesy valve cover black, replace or paint the hose clamps black, same with the green cap on the coolant reservoir (or find a way to black the whole reservoir if that's possible). Lose the sticker on the radiator cap, lose the sticker on the throttle body, heat-shrink all the cables in black. I'd probably also paint the rad black.
Other colours are available ofc.
Also, your screws from your headlight surrounds are missing
I replaced the black vacuum lines with neon pink ones because tuner vibes innit.
I only just painted the valve cover red, I think it looks awesome! I was originally going to do it crinkle black or high gloss black, but I'd never done the whole "red valve cover +5hp" thing before, and I had some BMW red sitting about.
Hose clamps look better with a bit of contrast IMO, but I might replace them with narrower ones which are all uniform.
Black coolant res cap would look pretty good! But not fussed really. Not going to cover it completely cos I like being able to check the level easily.
Agree on the radiator cap sticker! Just haven't peeled it off yet.
The "throttle body" is the intake manifold! And I kinda like the stickers, I did put them there after all.
Agree on blacking out the cables, but that sounds too much like work to me.
The rad core has already been sprayed black, doesn't show up well in pics though. But I might get a shroud that covers the gap between it and the front bar.
Those holes are for clips which I don't have.
But the headlight surrounds are part of the bumper so its fine.
BTW
@Akagi I hope you don't think I'm dissing your ride, I do rather like it and this is purely meant as some ideas rather than pooping it <3
All good! The engine bay is the nicest part currently though.
Slowly working on things...
