- 14 Aug 2009
Pretty bad still with the stuttering.
Nvidia doing very well in some of the newer UE 5 titles:
Palworld im Benchmark-Test
ComputerBase hat 28 Grafikkarten in Palworld getestet. Benchmarks in FHD, WQHD und UHD zeigen die Leistung des Spiels.www.computerbase.de
3080 still going strong @TNA![]()
Haven't played palworld in a while now but may return when it gets more content.
Everything computerbase publish has the Nvidia GPU's beating equivalent AMD GPU's by 50%, is this why you're constantly posting links to their website? Its like someone constantly posting UserBenchmark links in the CPU room.
Weren't computerbase regarded as the gospel source by amd fans not long ago? I can't keep up with who is and isn't trustworthy now![]()
I've been around a long time, no one in the UK has ever heard of them until you started linking them here.
Also, UserBenchmark are considered as gospel by more people than not.
Lttmatt and a few others used to refer to them all the time and considered them to be "trusted".
This is a good overview and info on all games using UE5 coming out:
That's the thing, shader precomp is missing and is done at runtime.That's normal? Unless you mean the game builds shaders whilst running instead of doing a pre-compilation step on first launch after installing a driver or game update?
I'm assuming precomp is being done at launch, but people are too impatiant and just load into a game anyway before shaders have compiled which is a feature of almost all games that do shader precomp.
Have been following them on social media for a couple of months and they're really putting a ton of work into the lore side of things. If the game itself has as much TLC put into it, it could be special!
Another UE5 title coming, this looks rather cool. Never played Mass Effect, so this might be a good start with something new like this.
