Which is fine but in reality bicycles don’t act as solid objects either. There whole frontal area is a leaver held in place a squishy human rider. In reality, it moves when it hits something which dramatically lowers the forces involved, not dissimilar to pedestrian safety design in a car. It’s also likely to be traveling at a slower speed.Bit of a check here, cars are designed to absorb pedestrian energy. Bikes arn't, locallised pressure of a handle bar on a child skull is likely to be worse than a soft deformable bumper and bonnet surface.
The comment about a cyclist being able to stop more quickly is just what happens in the real world rather than a contrived brake test.True, but nothing to do with braking power. Even a rim brake on a bike has enough power to lift the back wheel off the ground, which is the point of maximum deceleration. Better brakes or more grip won't help at all. The limit is due to the relatively high centre of mavity, bracing the arms and keeping the weight as far back as possible increases it.
I looked up the numbers a while back and a cyclist can manage about 0.5G before the point where they go over the handlebars. Typical cars can manage between 0.7 and 1G.
A collision with a predestination is much more likely to happen in an urban environment.
The cyclist is much more likely to be traveling more slowly than a car, it just can’t accelerate as fast. Most cyclists can’t sustain 20mph without a significant gradient on a bike anyway where as a car will happily cruise at 30 in the 20 without even thinking about it.
The cyclist is also much more likely to be paying attention to its surroundings and are more likely to avoid the collision in the first place given they are having to pay attention to all the cars trying to kill them.
Cyclists mix much more closely with pedestrians than cars but accident rates are lower and the KSI stats are not even measured on the same scale as car vs pedestrian.
Ask yourself, what would you be rather hit by, a cyclist or a car?
I’d take cyclist any day of the week.
